4agze missing/no power :(
I bought a ae101 levin 4agze and its missing sometimes.
Sometimes when you start it up the revs drop and it turns off.
It doesn't have any power at all when you going uphill.
Cant fell the torque.
The person i bought it from said it might be a stuck valve.
What else could be the problem?
- Dell'Orto
- ** Moderator **
Checked the engine codes?
- AE92-5ONIC
- Toyspeed Member
- AE92-5ONIC
- Toyspeed Member
nz_climber
- Toyspeed Member
- Contact:
- Dell'Orto
- ** Moderator **
nz_climber wrote:take it to a mechanic.
Next to impossible to diagnose over th net
KIPH8N wrote:AE92-5ONIC wrote:http://www.troublecodes.net/Toyota/
looks quite confusing
Go in the enginebay look for a small black box that says diagnosis. Open it up. grab a paper clip or any sort of wire and jam one end in the terminal TE1 and the other end in E1 (there should be some sort of labeling as a reference). Now go and turn ignition on so that the lights come up on the dash eg.oil, brake, check engine light etc. Dont start the car.
follow the easy instructions below
Count number of flashes from CHECK ENGINE light.
If system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuously
and evenly about 2 times a second.
Otherwise, the light will blink a number of times equal to the trouble code as follows:
The light blinks only (.5 second ON, .5 second OFF) when indicating a number.
The light will be OFF for 1.5 seconds between the first digit and the second digit of the code.
If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed.
Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat.
The diagnostic code series will continue to repeat as long as the check connecter terminals TEl and El are connected.
When finished, remove the jumper wire.
Its that easy.
You might have to do the count a few times to make sure you have the correct codes.
Get into it and start learning how to do some shit yourself.
Previous:
Previous:
328FTW wrote:I had an issue like this. The centre of the electromagnetic pulley for the supercharger had come clean off, must have come loose.
But still mechanic is in order. If you can have it compression tested and right down what he says. Loads it could be, coil breaking down etc etc
Some belt on the car makes a sqiky sound when accelerating i think its the supercharger belt. Could that be an issue?
TRD_ZERO wrote:KIPH8N wrote:AE92-5ONIC wrote:http://www.troublecodes.net/Toyota/
Its that easy.
Haha nice one man. Yes i shall do it tomorrow
Lets see what i get.
- Adamal
- Toyspeed Member
KIPH8N wrote:Some belt on the car makes a sqiky sound when accelerating i think its the supercharger belt. Could that be an issue?
Well that sounds like the electromagnetic clutch is engaging, but the belt might need replacing. Check to see if its hard and cracked.
Adamal wrote:KIPH8N wrote:Some belt on the car makes a sqiky sound when accelerating i think its the supercharger belt. Could that be an issue?
Yes the belt is hard. Where do i get a belt from? Does repco sell them?
- h8wrxs
- Toyspeed Member
- Location: travelling to candy mountain with my magical leoplurodon
KIPH8N wrote: Does repco sell them?
those questions alone tell me youd be best to go to a mechanic who knows what they're doing
The four seasons in Australia consist of "$$% it's hot", "Can you believe how $$% hot it is?", "I won't be in today because it is too $$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
