AVS Boot Out / Boot Release
Post Reply
BZG Wagon
Post by BZG Wagon »
The AVS alarm in my Terrano has a wire labled 'boot out'. I want to hook up the alarm so the rear boot window unlocks (+12v) however when I press the boot release (left button on the remote for 3 seconds) nothing happens other than the alarm chirping a couple times.
Is anyone familiar with AVS installs and what I need to do to get this working?
Post by Dell'Orto »
How is it wired in? Output to a relay to the window motor I take it?
BZG Wagon
Post by BZG Wagon »
The alarm or the boot?
...not sure - are you saying I need to wire +12v to the alarm, to provide power to the boot release?
Post by Dell'Orto »
No, more asking how is the alarm triggering the boot release? Is there an output directly to the boot release motor or does it trigger a relay?
BZG Wagon
Post by BZG Wagon »
Oh - sorry.
There is a an output wire labled "Boot Out" coming from the alarm, running 0.30v when connected to the multimeter. When I hold the boot release button for 3 seconds the alarm chirps twice and the voltage jumps to 0.60v for a few seconds, before dropping back to 0.30v.
From what I gather from the user manual (not the installation manual) I do not require a separate relay / part to trigger the boot. I was hoping / expecting the 'boot out' to spike to 12v, which would have triggered the existing boot relay.
Post by Dell'Orto »
Right, that makes sense. Obvious question - but you have checked to see it is actually connected to the relay?
Grrrrrrr!
Post by Grrrrrrr! »
0.3 to 0.6 volts sounds like it is a transistor being turned on to sink a current. Try putting a largish (say 1K ohm) resistor between 12V and the alarm output and seeing if it then becomes 12V, pulling down to ~1V when you activate the output.
BZG Wagon
Post by BZG Wagon »
Dell'Orto wrote:Right, that makes sense. Obvious question - but you have checked to see it is actually connected to the relay?
Fairly sure; I connected the wire right after the interior boot switch (i.e. 0v side - diagram below minus the resistor).
Grrrrrrr! wrote:0.3 to 0.6 volts sounds like it is a transistor being turned on to sink a current. Try putting a largish (say 1K ohm) resistor between 12V and the alarm output and seeing if it then becomes 12V, pulling down to ~1V when you activate the output.
Thanks - will give it a try. Would wiring it per the below diagram work (apologies for my MS Paint skills):
Contact:
Post by Bling »
Ask: XS1V
Post by sergei »
With low active/sink switches you supply "ground" to the relay (while 12V is constant). So your diagram will not work. You will need to drive a separate relay to achieve what you want (providing your alarm is OK and you have not blown the output transistor by applying 12V to it), or if alarm allows it, switch the mode of operation of the output.
BZG Wagon
Post by BZG Wagon »
Cool thanks for the info. I'll give it a shot & see what happens.
Haven't applied +12v to the boot out so the alarm should be okay.
XS1V
Contact:
Post by XS1V »
It's a negative out put rated at 200mA. If you need a positive output you will need a relay. Are you running the onboard turbo timer? If so boot out no longer works as this wire becomes secondary ignition control.
Brad
ST205 Group A Rallye #2363
BZG Wagon
Post by BZG Wagon »
I can't find anywhere in the owners manual on how to program it to Turbo Timer vs. Boot Out. It's not connected to a turbo timer so I'm hoping by default it's set to boot.
simonlenihan
Contact:
Post by simonlenihan »
BZG Wagon wrote:I can't find anywhere in the owners manual on how to program it to Turbo Timer vs. Boot Out. It's not connected to a turbo timer so I'm hoping by default it's set to boot.
From memory it is set to boot out from the factory, hold the button down for 3 seconds and it will produce a negative output.
You can program it to instant boot release too if you want.
Programming instructions are in the installation manual, any AVS installer should help you out.
2011 Toyota Hiace ZL
1994 BMW 740iL e38
XS1V
Contact:
Post by XS1V »
If you need any programming help then PM me since I design the programming settings and write the manuals 8)
Brad
Post Reply
