Prado Engine: 1KZ, 1KD or 1GD
Post Reply
solitaire
Post by solitaire »
Hi, After some advice please folks.
Looking at upgrading the family wagon.
I'm at a bit of a loss of engine choice. I can get what we want in the above three engine choices. Keen on your views, please mention if you look after these for a job.
As I see it:
1KZ:
Pros:
Old Reliable powerplant, just gotta keep the coolant and oil fresh.
Long engine life
Cons:
Ho Hum Fuel economy
Not a lot of get up and go above 80kmh (based on my experience with our old Surf)
Oil changes every 5000km's get a bit expensive
1KD:
Pros:
Efficient Engine
Being a diesel, it should be good for 500,000kms hopefully?
Cons:
I've read online that these are a tad unreliable/need a lot of expensive maintenance (can anyone confirm this?)
1GD:
Pros:
Simple Petrol Engine, hopefully very reliable and relatively low maintenance as a result?
Cons:
I'll be lucky to get more than 300,000kms out of this engine?
High Fuel Cost
I'd be ok with the higher fuel cost of the petrol if I could expect 400,000km's out of it, unrealistic?
Also if you have any recomendations on alternatives to a prado (7 seat, big wagon) please sing out.
thanks guys and gals
AE92, KZJ120, KDJ120
1I1
Contact:
Re: Prado Engine: 1KZ, 1KD or 1GD
Post by 1I1 »
The 1KZ has a bit of a history with cracking heads. Towed my Corolla to Taupo and back the other week with one and used SFA diesel to do so but was oh so slow and painful to pass.
TRD Clicky >>Here
solitaire
Post by solitaire »
1I1 wrote:The 1KZ has a bit of a history with cracking heads. Towed my Corolla to Taupo and back the other week with one and used SFA diesel to do so but was oh so slow and painful to pass.
Cheers mate, i've read toyota NZ recommend changing fuel filter every 15,000km's and lot's of injector issues with the 1KD - heard any of that?
1I1
Contact:
Post by 1I1 »
Fuel filters are 30k. Injector issues are mostly seen with the Hilux.
TRD Clicky >>Here
glowee
Post by glowee »
have seen some 1kd hiaces fo inexcess of 400,000 with out a issue, but later 1kd seem to be the way to earlier do have a couple of issues
1998-Caldina GTT-White
1993-Corolla XL 1300cc-Blue-NOW Getting the 4AGE treatment!
1998-Levin-Silver (SOLD)
1995-Corolla Wagon- White (SOLD)
Post by Dell'Orto »
1KD is good as long as you keep on top of injector maintenance
solitaire
Post by solitaire »
Dell'Orto wrote:1KD is good as long as you keep on top of injector maintenance
In terms of replacing every 40k's?
The wife wants a discovery 3.... i think it's a bad idea reliability wise - they are in the price range but that's probably for a good reason - any thoughts?
Post by Dell'Orto »
The washers, yup. Not the injectors themselves!
Touch a Disco at your own peril! :lol:
solitaire
Post by solitaire »
Dell'Orto wrote:The washers, yup. Not the injectors themselves!
Thanks, understood re washers.
So a disco 3 is as unreliable as the disco 2?
Contact:
Post by matt dunn »
Just as unreliable, but more expensive to fix.
solitaire
Post by solitaire »
Yuck, ok - cheers, heaps of internet research said they were better. But mind you those were land rover forums...
Al
Contact:
Post by Al »
You need a black Q7 for the school run Chalky.
Contact:
Post by matt dunn »
solitaire wrote:
matt dunn wrote:
They are the type of people who see unreliability as a feature, not a fault.
Post by strx7 »
sounds like you need a 7 seat 80 series cruiser.....
or 100 series if you have alot more money to spend
Post Reply
