Caldina Sounds...
Caldina Sounds...
I was thinking about replacing the factory speakers in the doors of my 98 Caldina and am really keen to know what size they are so I can buy them now, install them later and without taking the door panels off.. so if anyone could please help with speaker size in inches or cm's that would be wicked! Oh and one more thing... where is my aerial?? so I canmake it better? - thanks in advance!
We upgrded our sounds recently, our factory fronts were 5 1/4" but we replaced those with 6" components
1999 Caldina GTT (Manual)
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1327
As for the aerial, you just need to get a signal booster/amplifier (about $30 from supercheap) - (the aerial is in the rear quarter windows)
86_rolla wrote: so spacers might be needed.
Yep we needed spacers - used snwtoys method of using cookie time lids
Yep signal booster can go behind head deck.
As for the speaker install - my partner did it for me, and I heard a few nasty remarks along the way so I'm guessing it may get a bit tricky
But yeah they are now nicely tucked in behind the door panel
ADIKTD wrote:Awesome!!where abouts is that found? and what if you have an amp attached to the remote part of your Head deck?
Depending on the head deck, you may have a separate 'aerial' output which you can connect to the signal booster. Otherwise you should hook the amp remote and signal booster wires together, and connect to the 'remote' from your deck.
