The house isn't too flash (nothing bad though) at the moment, but renovations are in the pipelines, anyone living in the house can have a say in colours and stuff.
The room is fairly large with built in wardrobe and a view over the Glenfield Valley, unfurnished. House furniture is fairly mismatched at this stage as it's being done on a bit of a budget, chances are that any stuff you have can be used
Your social gatherings are ok with reasonable notice.
Biggest problem is parking, house is down a right of way and currently only has two carports (converting to 3/4 car parking is high priority), big cars may struggle and theres no room for second cars unless you're happy to park on the street. Plenty of storage space though.
$130 p/w +exp (could look at negotiating if you have good references)
Also available soon is the apartment, it's a large bedroom w/ ensuite, private deck and a second, smaller room with kitchenette and room for a small table. Would suit couple. Simply unlock the door to use full kitchen, lounge etc. Bedroom and deck look out over the Valley and are a seperate wing of the house.
$250 per week.
Ad is probably a bit all over the place, I'll check it over in the morning
