Mmm, Boost wrote:Colliers in Levin have a very good rep.
2LTR Rona wrote:for the bebuild on the bluetop I used engine rebuilders in New Plymouth and couldnt be more happy with the results and the pricing aint too shabby either.
Probably isnt much help at this stage due to the distance, but its another option i guess
B1NZ wrote:Mmm, Boost wrote:Colliers in Levin have a very good rep.
F**#$%$# Ass**%$#%$#%
Mmm, Boost wrote:B1NZ wrote:Mmm, Boost wrote:Colliers in Levin have a very good rep.
Care to expand on that?
CAMB01 wrote:Hey pies was gonna suggest Kerry Lindsay, but you called in today .
You looking to get work done on your AE92?
pc wrote:I gave them the block, head, and 0.5mm head gasket and told them to work out how much to take off the head to get the compression ratio to 11.5:1. I also said that I realised it would become an interferrence engine and that was fine with me.
I got the engine back with the head torqued down, put the cams in, and put the engine in the car. After running the engine in I had some doubts and measured the height of the head, and some other 4AGE heads that I had. measuring showed that nothing had been taken off (and I was expecting a little over 1mm to be removed).
It took me a long time to getting round to pulling the head off again and taking it in to get planned.
They planned it for free, after I demmanded so, but they didn't bother to tank the head and clean the shavings out of it... all-in-all a very simple job made difficult because they refused to do what I asked for.
The torque increase in the lower rev range was quite significant after the CR was raised, and made the car much easier to drive.
Pies wrote:i had some head work done ages ago with KL in porirua, so i think im gonna go back there again as i havent heard anything bad about them, and i know cam will do a good job of it
Return to Wellington / Lower North Island Region
