WTB Panel beater with bare metal wide body expirence?
Postby Shrike » Wed Dec 21, 2011 2:06 pm
Anyone on here know of any panel beaters that have expirence with this basicly I want the rear 1/4 to look the same but be 67-70mm wider
I am widening the front gaurds as well but only 52-55mm (and im happy to do them myself as a f**k up just means a new set)
The rear 1/4s however if I screw up then it means I need a new shell
I am currently trying to located a rear cut and a spare crashed body (as long as the rear ends ok) to either use to have ago myself or give use in the widening
Why dream it when you can live it
Shrike
Postby Dell'Orto » Wed Dec 21, 2011 7:36 pm
Custom Autoworx in Upper Hutt did CNDYMN/STILYN's body I believe
Postby Mr Ree » Thu Dec 22, 2011 3:41 pm
Metal widebodys rule.
Its the long way to go about things, but its definitely the right way :)
wak thud gush!
Mr Ree
Postby Shrike » Thu Dec 22, 2011 3:51 pm
Mr Ree wrote:Metal widebodys rule.
the front gaurds will be made out of carbon eventually but ill start off in metal :p
Shrike
Postby CAMB01 » Thu Dec 22, 2011 6:22 pm
Dell'Orto wrote:Custom Autoworx in Upper Hutt did CNDYMN/STILYN's body I believe
Ryan who used to work there did the panel work. He is now my boss at a different business.
He has no spare time anymore to do anything like that.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby ~SlideWays~ » Fri Dec 23, 2011 9:01 am
Ryan who used to work there did the panel work. He is now my at a different business.
Custom Autoworx down sized a lot didn't they?
~SlideWays~
Postby CAMB01 » Fri Dec 23, 2011 12:04 pm
He just didnt want to be a panelbeater anymore.
CAMB01
Return to Wellington / Lower North Island Region
