WTB Panel beater with bare metal wide body expirence?
Postby Shrike » Wed Dec 21, 2011 2:06 pm
Anyone on here know of any panel beaters that have expirence with this basicly I want the rear 1/4 to look the same but be 67-70mm wider
I am widening the front gaurds as well but only 52-55mm (and im happy to do them myself as a f**k up just means a new set)
The rear 1/4s however if I screw up then it means I need a new shell
I am currently trying to located a rear cut and a spare crashed body (as long as the rear ends ok) to either use to have ago myself or give use in the widening
Shrike
Postby Dell'Orto » Wed Dec 21, 2011 7:36 pm
Custom Autoworx in Upper Hutt did CNDYMN/STILYN's body I believe
Postby Mr Ree » Thu Dec 22, 2011 3:41 pm
Metal widebodys rule.
Its the long way to go about things, but its definitely the right way :)
wak thud gush!
Mr Ree
Postby Shrike » Thu Dec 22, 2011 3:51 pm
Mr Ree wrote:Metal widebodys rule.
the front gaurds will be made out of carbon eventually but ill start off in metal :p
Shrike
Postby CAMB01 » Thu Dec 22, 2011 6:22 pm
Dell'Orto wrote:Custom Autoworx in Upper Hutt did CNDYMN/STILYN's body I believe
Ryan who used to work there did the panel work. He is now my boss at a different business.
He has no spare time anymore to do anything like that.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby ~SlideWays~ » Fri Dec 23, 2011 9:01 am
Ryan who used to work there did the panel work. He is now my at a different business.
Custom Autoworx down sized a lot didn't they?
~SlideWays~
Postby CAMB01 » Fri Dec 23, 2011 12:04 pm
He just didnt want to be a panelbeater anymore.
CAMB01
Return to Wellington / Lower North Island Region
