where to get driveshaft custom made?
Postby Soarer T » Wed Jan 03, 2007 11:12 pm
anybody know a good place doing driveshaft custom made. just doing mk3 manual conversion atm.i have only got an auto one, so just want to find a place who could make a manual one out of auto one. any ideas would be appriciated.cheers.
Soarer T
Postby Dunny » Thu Jan 04, 2007 9:52 am
You could try circle track engineering as a starting point....parkhouse road
Haven't used them personally so couldn't comment on workmanship
Dunny
Postby johntramp » Thu Jan 04, 2007 11:44 am
circle track is good. will cost about $120 including balancing if you supply the 2 shafts to be joined and was done within 24 hours.
johntramp
Postby Soarer T » Thu Jan 04, 2007 11:58 pm
the problem is: i only have one auto shaft. anyway, i will give them a call to see how it goes. cheers for the infor.
Soarer T
Postby 4000GT » Sun Jan 07, 2007 11:54 pm
How did this go in the end? I will need one soon and any opinions would be appreciated.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby Soarer T » Tue Jan 16, 2007 10:00 pm
cicle track is pretty good. they cut the middle piece between the yoke and the bearing side, reweld a longer piece and balanced it. cost about 150 bucks. but you need to bring the measurement to them.good guy to deal with.
Soarer T
Return to Christchurch / Upper South Island Region
