big_boy wrote:
7M add 12v+ to th FP connector on check connector to check pump or 2 check relays EFI relay must be closed circuirt opening relay must be closed pins 1-2 (ground pin 4 (green wire) to achive this) & fuel pump control relay must be closed connecting 1-4 (ground pin 3 (green wire red stripe yellow bands) to achive this)
is that what your after?
Return to Christchurch / Upper South Island Region
