WTD: Someone with a lathe
Postby Bling » Thu Jul 16, 2009 9:37 pm
Does anyone have or have access to a lathe?
I have an axle that i'd like to get shortened and have the diameter reduced along its length to 25mm with a couple of smaller step downs on the end.
Anyone able to help me out? :D Cheaper the better :oops:
Cheers Any recommendations for places to go for this would also be a great help.
Postby frost » Thu Jul 16, 2009 10:06 pm
graham at 0800cartune has a lathe. should ask him what he'll charge. he is setting up a lot of machines for all sorts of machining work.
Postby Bling » Thu Jul 16, 2009 10:14 pm
Oh true haha I'll hit him up and see what he says, cheers! 8)
Postby fangsport » Fri Jul 17, 2009 12:01 am
do you want a smaller axle??
probably have a KP one
fangsport
Postby Bling » Fri Jul 17, 2009 12:23 am
Nah axle size is sweet as, its just that none of the thicknesses are good sizes. All the sizes are random.
Been into a couple of bearing specialists and they measured it all up etc and said 25mm is the best diameter. Can do other sizes but the size the axle is, doesn't suit anything. I think the axle is mostly 26mm (ish) its not quite, and so easiest way is for my to get it all lathed down to 25mm exactly, then I can easily get bearings on there and she'll be sorted.
Cheers though :)
Postby Elmo » Fri Jul 17, 2009 9:15 am
25 mm seems an odd size, you sure its not inch? (yes, even on a jap car)
Elmo
Postby Bling » Fri Jul 17, 2009 9:39 am
Yeah both places said 25mm is a standard size, so should be correct.
The axle is ~26mm but isn't exactly that, so needs to be lathed down, so 25mm is the best size aparently. Probably common I guess.
Postby Elmo » Fri Jul 17, 2009 10:35 am
Ah fair enough, just seems a little odd, ut suprizingly enough, the bearing people SEEM to know what they talking about Ocassionally! 8)
Elmo
Postby 7apples » Sun Jul 19, 2009 7:02 pm
25 is alot more common than inch (25.4). and both are more common then 26ish as the ish is hard to get a size for :)
How you like them apples??
7apples
Postby Bling » Mon Jul 20, 2009 10:23 pm
Sorted cheers. Graham sorting me out :)
Return to Christchurch / Upper South Island Region
