Dyno Results
Dyno Results
Postby Rollux » Mon Aug 31, 2009 6:53 pm
Well, had the car dyno'd today. All was well, altho a bit lower than I expected - drivetrain loss of 27% if Toyota's claim of 141kw@fly is true (I'm suspecting not)
http://cid-3b6f8f298818570b.skydrive.li ... 20BEST.JPG
numbers were
103.3kw (138.5hp) @ 8100rpm (also @ 7000rpm, then dips slightly, then up again... :? )
AFR's around 10.8-11.4!!
Conditions
http://cid-3b6f8f298818570b.skydrive.li ... 009028.jpg
Vid
http://cid-3b6f8f298818570b.skydrive.li ... %20run.mp4
The whole workshop came out to see what was going on - and these were V8 nuts! One of the older guys said to me "Put a decent metal intake on it, will help the peak power and sound like nothing on earth"
So, I have a base figure. A base run down the strip Octber and I'll be set to mod.
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby frost » Mon Aug 31, 2009 8:52 pm
is this from the 2zzfe? sorry im old school iron and don't much about alloy block motors,
Postby Rollux » Mon Aug 31, 2009 9:32 pm
2zzge
Rollux
Postby BWDOWN » Sun Sep 06, 2009 9:38 pm
Hub or rolling road?
B20vtec Allmotor 90% of the way to 170wkw Thanks to 0800 cartune 41.co.nz & Spec Performance
My Profile
BWDOWN
Postby Rollux » Mon Sep 07, 2009 5:42 pm
Rolling road
Rollux
Postby MAGN1T » Mon Sep 07, 2009 9:51 pm
How come you're getting different AFRs for the runs. Is the wideband playing up?
An AFR of 11 seems a bit richer than what you'd normally get from an N/A car (so loosing power).
Looks like the sensor was put up into the tailpipe and getting readings after the cat, which looks like it's working properly.Maybe the wideband needs calibrating or the sensor replacing?
It's good that you're dynoing a stock car, I thought I was the only one who did things like that. It takes all the BS out of it once you mod it and get more readings.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby frost » Mon Sep 07, 2009 10:01 pm
MAGN1T wrote:How come you're getting different AFRs for the runs. Is the wideband playing up?
Steve
it could also be the toyota tradition of over fueling maps, and too many safe guards for reliability sake,
Postby Rollux » Tue Sep 08, 2009 11:02 am
look at the times of the runs and the AFRs - the second run was 1 min after the first and had the richest AFR due to the extra heat in both coolant and air temp. The last run had a cool down period and has leaner settings and more power.
Those AFR's are normal for one of these in stock form. CAI and headers with decat leans them out a wee bit, Power FC will fix the rest.
Magn1t - no, I like to know what actually does what. not one of the BS brigade. plus i'm in the same class as the honda boys when I drag, so I need to know how much I've got so I don't line up against the wrong cars and lose to a Honda!!
Rollux
Return to Christchurch / Upper South Island Region
