Rebuilding Bilsteins
Postby FST4RD » Fri Jun 01, 2012 2:36 pm
Does anyone here know how to rebuild Bilsteins?
Is it the sort of thing you can do yourself?
I have experience rebuilding RC car shocks and mountain bike shocks, but Im assuming car shocks are quite different?
Can anyone give me a rough price on a rebuild?
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby DRFTIN » Fri Jun 01, 2012 3:50 pm
autolign
dont think its a diy kind of thing like pulling apart old shocks and pouring some gear oil on
DRFTIN
Postby fangsport » Fri Jun 01, 2012 6:15 pm
suspensiontech in Auckland rebuild and revalve them.
fangsport
Postby TRDWGN » Fri Jun 01, 2012 8:38 pm
fangsport wrote:suspensiontech in Auckland rebuild and revalve them.
Now there's a man that knows about bilsteins +1
TRDWGN
Postby FST4RD » Fri Jun 01, 2012 9:23 pm
Any idea on cost?
1 of my factory subaru front ones has a slight leak and weeping ever so slightly.
I assume I need to get both fronts done rather then just 1 side?
FST4RD
Postby Mr Revhead » Sat Jun 02, 2012 1:05 am
Ah Subaru ones? Costs a bit as they had to modify them as they develop a wobble in them. Around $300ish each it used to be
Need to install a new top to the body to support the shaft
Postby Bling » Sat Jun 02, 2012 1:08 am
FST4RD wrote:I assume I need to get both fronts done rather then just 1 side?
If one is going, chances are the other one will be in similar condition. You wouldn't really want one rebuilt shock and one well worn shock paired up either.
Return to Christchurch / Upper South Island Region
