Window tint removal??
Postby AE-0000 » Sun Sep 02, 2007 7:42 pm
Any one know a good way to remove window tint film, i remove most of it already at the rear window but there are still sticky bits left at the bottom of the screen. Can't seem to scape it off as the rear window is way to narrow (AE111) and i don't want scape the heater coils.... anyone know any liquid solution that will do this??
AE-0000
Postby flygt4 » Sun Sep 02, 2007 7:43 pm
3m have a product called solv-all or sumthing that is really good for getting sticky residues off after removing labelling etc
flygt4
Postby HachirokuGTV » Sun Sep 02, 2007 7:50 pm
Or try Dissolve-it. Get it at the supermarket. Works well.
HachirokuGTV
Postby Luke28 » Sun Sep 02, 2007 7:50 pm
turps is good for removing stuff like that
Luke28
Postby AE-0000 » Sun Sep 02, 2007 9:30 pm
Sweet will give it a try sometime.
AE-0000
Postby andyztouring » Sun Sep 02, 2007 10:23 pm
Use a heat gun/hairdryer to soften and remove the film,then clean the sticky residue off with methylated spirits,comes up clean without leaving streaks.Would not recomend using turps as it will leave a greasy surface.
andyztouring
Postby bluemaumau » Sun Sep 02, 2007 10:44 pm
wait for a really hot day then just use some turps.
i tried doing mine one night and got $&#$% off cause i spent like 2 hours on a window, so i went to sleep, gave it a crak the next day at like 1pm when the sun was cranking and wallah, i did the whole wagon in 30 mins :lol:
Postby IH8TEC » Sun Sep 02, 2007 10:48 pm
i used heat gun, hairdryer work just same. and then cleaned the window with a citris cleaner, smelt nice too lol,
if using meths or whatever, just leave the windows down for a bit let the car air out unless you wanna get high :)
