Caldina: GTT Strut brace - Trying a workaround...
Postby snwtoy » Tue Jul 05, 2011 10:56 pm
I begin to think it's been bent too. What was the condition of the car it came off?
snwtoy
Postby Sick Puppy » Tue Jul 05, 2011 11:05 pm
snwtoy wrote:I begin to think it's been bent too. What was the condition of the car it came off?
No idea, purchased off of Tardme.
I say Tardme rather than Trademe, as I'm now starting to feel a bit of a 'tard for buying it. :lol: Meh, $30...
I will be checking with the seller.
Project thread here
Discussion thread here
Sick Puppy
Postby snwtoy » Tue Jul 05, 2011 11:18 pm
Probably written off after a t-bone through the A pillar :?
snwtoy
Postby Sick Puppy » Tue Jul 05, 2011 11:52 pm
snwtoy wrote:Probably written off after a t-bone through the A pillar :?
Knowing my luck lol
Actually, while I remember, did you ever find your cargo shield? Did it have any clips?
Project thread here
Sick Puppy
Postby Bling » Wed Jul 06, 2011 12:26 am
Cut 40mm out of the centre, put smaller pipe inside, fit brace to car, weld in position.
Well that's what i'd do, but I weld things for the hell of it, so my opinion is biased.
Postby Sick Puppy » Sun Jul 31, 2011 1:37 am
Finally got my s*** together and rang the guy I purchased it from - he got it 'off a mate" with a GTT, it wasn't known to have had any accidents... no idea at this point really, I might try and straighten it out to get the length right, will post what happens.
Project thread here
Sick Puppy
Postby strx7 » Sun Jul 31, 2011 1:48 pm
Anth_555 wrote:i dont think jackin the car up to get the brace to go on is agood idea. the idea of a brace is to reduce movement not hold something in place. there realy is only to reasons why it wont fit. 1 its the wrong brace or 2 and most likly its bent
cars can flex alot. and to twist a car so much to get a brace to fit can only make more problems then good
some of the suzuki escudo's & vitara have factory strut braces on them, you'd be scared to see how much the mounting points move with the brace off.
Postby Mr Revhead » Sun Jul 31, 2011 4:14 pm
Yeah they are often under tension when you fit them.
I'd say it's been bent. Bend it back.
I wouldn't be jacking one side or anything to try and fit it. And if you can get 10mm from doing that, but a new car 8O
My old 101 I think it was, when you took the brace off it would "spring" in and you'd have to use a little grunt to open it out to re fit it.
Postby Bling » Sun Jul 31, 2011 4:58 pm
Fitted one to an AE111 and it slipped on without any fuss at all. But as they say I guess, if it doesn't fit force it. If it still doesn't fit your hammer isn't big enough!
