diss7 wrote:rollaholic wrote:i bet your penis is bigger too
That's kind of racist.
its ok, its only akane
Stott69 wrote:Back to topic, well sort ofDVSMOTORSPORT wrote:When checking for play, make sure when you are releasing pressure off the bar you release all the pressure, eg your bar looses contact with the tyre. Also jack up in the center so that both tyres are off the ground. A swaybar can hold pressure on the suspension so that you cant feel any play.
If its wheel bearing would you feel the play with a wheel on the ground?
I've been failed on play and told bearings but can only bearly feel it, but only when the whole back ends up?
Users browsing this forum: Majestic-12 [Bot] and 27 guests
