Postby loudstealthGT-Four » Sun Jul 27, 2014 9:47 pm
Removed rear quarter windows as my sealing technique was less than ideal, water was running in and filling the floor. Resealed them and put a small amount on polyurethane on some gromets sealing the holes left from removing the rear window wiper and rear window squirter, Wish I'd just welded them up before it was painted, but hadn't foreseen me removing them....
Car is now 100% water tight and ready for Interior reinstallment.
loudstealthGT-Four
Postby Boosted_162 » Mon Jul 28, 2014 11:45 pm
Ordered some Megan Racing front camber arms. Hopefully the last thing I need to buy!
Postby thegreatestben » Thu Aug 07, 2014 11:46 pm
Got my long wheels studs from Japan, means I can finally fit the wheels I picked up:
Before:
After
Now I should wash it...
thegreatestben
Postby Bling » Sat Aug 09, 2014 11:55 am
Shit yeah, I like those!
Postby Makaveli » Sat Aug 09, 2014 1:27 pm
Nice wheels. What make/model?
Makaveli
Postby thegreatestben » Sat Aug 09, 2014 7:41 pm
They are OZ brand, bought em for $200 off the tard with tyres. 17x8.5" I think the tyres are 265 or 275 65's. All about 3mm tread
thegreatestben
Postby Kiwi-Corolla » Sun Aug 10, 2014 7:46 pm
Swept the concrete with my front lip :mrgreen:
Yesterday: Did an oil change and replaced the rubber seal between the oil filter union (no more annoying little drips in the garage).
Kiwi-Corolla
Postby Leon » Sun Aug 10, 2014 9:25 pm
Drove appliance Corolla to Taupo and back.
Now 472,000km on the clock and still going strong!
Postby Boosted_162 » Mon Aug 11, 2014 8:43 pm
Boosted_162 wrote:Ordered some Megan Racing front camber arms. Hopefully the last thing I need to buy!
Ended up not being able to get Megan Racing ones as they ended up being out of stock!
So instead have some SPC ones on the way via DHL. More expensive but they have a pretty good rep in the states. And get a fair bit more adjustment out of them apparantly.
Postby ®usty » Tue Aug 12, 2014 1:49 pm
(In the weekend I) removed the S54 from the Celica
®usty
Postby 1I1 » Sat Aug 16, 2014 9:26 pm
Last night: Removed part of the exhaust to fix a leak
Today: Had Rhyscar weld up the holes then fitted it back up, as well as all of the intake/plenum/airbox back in. The plenum hass a nice big lump added to clear the 70mm SQ Engineering stacks. Also added the wideband loom into the custom ECU wiring harness whynot made up. All ready for first startup on the Link tomorrow.... hopefully
TRD Clicky >>Here
1I1
Postby Grrrrrrr! » Sun Aug 17, 2014 12:13 am
Acquired a set of shimless buckets and a 7a waterpump pulley from Zebra, its great when you walk in and someone has already removed all the bits in the way and you just pick up the bits you want and walk out. Also found out the new Zebra yard is opening next month, and is 2mins from here.
Grrrrrrr!
Postby Mr Ree » Sun Aug 17, 2014 8:03 pm
1I1 wrote:Last night: Removed part of the exhaust to fix a leak
How did it go, mate?
wak thud gush!
Mr Ree
Postby 1I1 » Sun Aug 17, 2014 10:39 pm
All together and running. Ready to take down to Welly for Lith to tune in a couple of weeks.
Mark/whynot spent a bit of time sorting out the idle and various enrichment tables (beyond me haha). Took it for a bit of a drive so he could go over some of the tune (based off his own car). Sounds pretty angry past 5000rpm :twisted:
TRD Clicky >>Here
1I1
Postby Boosted_162 » Mon Aug 18, 2014 4:42 pm
Ordered some new front springs for my coilovers. If my decoding of part numbers is correct I have 10kg springs when it should have had 14kg.
Postby RomanV » Sat Aug 23, 2014 9:22 pm
Spent about 5 hours today getting to the root cause of the the problem with my diff having end float in the pinion gear.
Turns out that the front bearing was getting tight on the pinion shaft after getting wound about 3/4 way on, and the spline for the flange was tight too when getting to about that point.
Spent a feckload of time cleaning them and now it looks to all go together as expected.
Pretty dissapointed to have to deal with this myself after paying a workshop almost $500 to set it up, who messed up several things.
Ahhh well nearly there.
Postby Leon » Sat Aug 23, 2014 9:45 pm
Raced it.
Turns out with semi slicks on the front, and snow tyres on the back running 45psi, you don't need to touch the handbrake to pull a nifty 180 spin at any stage in a motorkhana test. Fun times.
Also took out first in class, and second overall for the series, so I'm happy with that.
Also, ran into I reckon bloody nearly every Toyspeeder near Manfeild!
Postby captain crescent » Sun Aug 24, 2014 11:19 am
Leon wrote:
Raced it.
I also went for a play at manfield after spending untill 1030 friday night getting it readt enough.
See the picture to see my car lurking behind leons.
Budweiser is a gay beer. if it isn't a gay beer Sam why are you trying to put it up my arse.
captain crescent
Postby Leon » Sun Aug 24, 2014 12:36 pm
and then you did massive handbrakeys and big smokey burnouts all the way through the motorkhana :D
Postby NILPSI » Sun Aug 24, 2014 6:55 pm
Leon wrote:Also, ran into I reckon bloody nearly every Toyspeeder near Manfeild!
We are all too close not to come and see what's happening!
17 Triton - The "free supplied by work" daily
09 Aurion Sportivo - The Daily
97 Trueno BZ-G - The Garage Queen
97 Supra SZ-R - The never ending project... now with added boost!!
NILPSI
