0 - 200 KMPH
Postby barryogen » Thu Feb 08, 2007 1:33 pm
Mmm, Boost wrote:
barryogen wrote:heh... thats with no wind/road resistance... most cars will also pull away in 4th gear quite happily on a dyno, doesn't mean that it'll work like that on the road.
Yeah, but did you read his sig? ;)
heh, somehow I missed that bit... umm, yeah, holy crap.
If I can get to 223.4(cops radar on closed road) in my little 141kw(at the engine) RunX shopping trolley, then I would say that you have a good chance of getting to 290(300 with diff) with a spare 333kw... at the wheels no less.
barryogen
2ZZ Guru in training
Postby Tumacki » Fri May 04, 2007 3:56 pm
ae111 trueno BZ-R off the clock (180kph) in 4th gear @7,000rpm.
Where do i get another speedometer with a higher cut off point?
Power is how fast you hit the wall... Torque is how far you take the wall with you.
Tumacki
Postby Bling » Fri May 04, 2007 5:06 pm
Its not the speedometer thats limiting you, its the ECU (computer) so unless you replace that, keep on dreamin
Postby vvega » Fri May 04, 2007 6:05 pm
BZG|Bling wrote:Its not the speedometer thats limiting you, its the ECU (computer) so unless you replace that, keep on dreamin
attually it is :(
without teh speed signal form the ecu it has no way of knowing how fast your going
so your both right
the speed cut is from the speedo
but no you cannot change it without some serious $&#$% around
vvega
Postby postfach » Fri May 04, 2007 6:15 pm
theres a circuit available from jaycar that is meant for calibrating speedos that use an electronic pulse, such as the digital dash in my soarer. If you put one of these units between the speedometer and the ecu you can alter the signal so the ecu thinks you're going slower than you are, hence bumping up your speed cut. It can alter it from 0% to 99% up or down.
I've got one in my car since i've changed from auto to manual, changed the diff and also the wheels, so speed was wacky. wire to ecu is non existent so it throws a code but i can still go as fast as i like.
postfach
no no no English!!!
Postby Tumacki » Mon May 07, 2007 10:01 am
i'll word it differently- by cut off point i didnt mean limit. i meant the last number on the gauge, (cut off point) is 180. where and how do i get another speedo and what speedo that will give me "a bigger final number"
Tumacki
Postby Mr Revhead » Mon May 07, 2007 10:06 am
you could put an nz new dash in it
Postby varix » Mon May 07, 2007 12:39 pm
Ive done 250ish on the back of a Suzuki TL1000. The whole time i thought i was going to die. Defiantly an amazing experience though.
varix
Postby Tumacki » Mon May 07, 2007 12:47 pm
........ from what other car.......
Tumacki
Postby Zak » Tue May 08, 2007 10:17 pm
a nz new ae111...?
Zak
Postby snwtoy » Tue May 08, 2007 10:51 pm
I've done over 200 in my evo, but the speedo stops at 190. The close ratio gearing is such that I don't think it would do over 230 top of 5th.
snwtoy
Postby matt dunn » Tue May 08, 2007 11:40 pm
snwtoy wrote:I've done over 200 in my evo, but the speedo stops at 190. The close ratio gearing is such that I don't think it would do over 230 top of 5th.
I ran my in a flying 1/4 event. It was an EVO 1 RS so supposed to have the short gear ratios in it,
100rpm off the limiter in 5th on 205/50/16's was clocked at 148mph,
which is about 238 kmh.
Postby snwtoy » Tue May 08, 2007 11:48 pm
Pretty close guess then aye :) Seat'o'the'pants workin well.
snwtoy
Postby DJ » Wed May 09, 2007 12:11 am
170kph in a AE85 3AU levin.
I win. :D
DJ
Postby scope » Wed May 09, 2007 9:20 am
fastest car for me to 200km/h would of been a ta63 celica with a worked 3t-gte.. that thing was insane
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby mr2--mad » Wed May 09, 2007 2:13 pm
my 600RR bike, any little straight on the open road, whack it from 6th to 3rd pin it and just after you change to 4th your there
ive seen 268 on the clock not bad for 600cc.
mr2--mad
Postby SkylineObsession » Wed May 09, 2007 9:56 pm
Haven't been over 180km/h yet. I think all speeds i've done/been over 150 km/h were in my car, and i've only driven it to the 180k limiter once.
SkylineObsession
Postby Mr Revhead » Wed May 09, 2007 9:59 pm
DJ wrote:170kph in a AE85 3AU levin.
I win. :D
175 in a 2k kp60. 3 up.
matt dunn wins :lol:
Postby Bling » Wed May 09, 2007 10:49 pm
what?????
any mods, that seems highly scented with bs to me :lol:
Postby Mr Revhead » Wed May 09, 2007 11:00 pm
dead accurate stock speedo! :lol:
looooong slight downhill run.
downhill + me as ballast = fast!
