Megameet: Trackday Monday 25 October Event Information
Postby Chelles » Thu Sep 30, 2010 10:15 am
Santa'sBoostinSleigh wrote:Chelles, are you happy for Kylie Jury (Taranaki Scrutineer guy) to check our cars our prior?
I am, however if he is going to do it let me send you the list of things we will be checking on the day so he can make sure they comply. :)
'96 RS Mirage Race car... (and when I'm a good girl; EVO 1!!) 2014 Toyota Hilux - daily driver!!
Gone but not forgotten: Race car AE85.6 Levin, AE101 Trueno, 84 MR2 AW11, 94 MR2 SW20, SR coupe KE35, AE92 FXGT, AE91 FXZS...
Chelles
TS Original Member
Postby Chelles » Fri Oct 01, 2010 5:38 pm
Goodness me plenty of emails waiting for me today... the main theme is "can I have a few more days to get my entry form in without the increase in price"... Simple answer is 'yup'...
If you are keen to come and haven't got your entry form to me yet I'll extend the $85 entry fee to 15 October. So lets see those forms coming in before then.
thank you to everyone who has entered so far. I'll be putting up a updated entry list over the weekend.
Thanks
Chelles. :)
Chelles
TS Original Member
Postby DexGT » Fri Oct 01, 2010 5:56 pm
Chelles wrote:Goodness me plenty of emails waiting for me today... the main theme is "can I have a few more days to get my entry form in without the increase in price"... Simple answer is 'yup'...
Thanks
Chelles. :)
Yay , this means I don't have to email you asking for more time , as I have discovered that the funny noise at shelly bay was my clutch making a hole in the diff housing :cry:
DexGT
Postby Chelles » Sat Oct 02, 2010 10:42 am
Oh no's!!!!!!! I'll hold a place for you... get to work :P (I know you will be)
Chelles
TS Original Member
Postby Truenotch » Mon Oct 04, 2010 6:27 pm
Might be able to make this now since the Saddle Road hillclimb has been called off.
Space for a WRX race car also? He wants to put down a few K's to see if he's overcome setup woes.
Truenotch
Postby EssDub » Mon Oct 04, 2010 6:49 pm
I will be finding myself some dollars and attending this with bells on, Chelles :) Will be good to catch up with ya :)
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby Chelles » Mon Oct 04, 2010 7:15 pm
Excellent!!!!
See you both there (send me an email for entry forms) :mrgreen:
Chelles
TS Original Member
Postby CAMB01 » Tue Oct 05, 2010 8:17 pm
Just another thing to let people know is battery placement and mounting.
In the engine bay is fine as long as the positive terminal is completely covered.
Not in the engine bay then it gets interesting depending on what type of battery you have, wet or dry cell.
If mounted inside the cockpit:
Musy be mounted on a flat metal base and have 2 insulated metal clamps affixed by a minimum of 8mm bolts and nuts in combination with under floor counter plates.
Wet cell batteries must be mounted inside an independently attached leak proof box vented to the vehicle exterior.
Dry cell batteries do not need to be mounted inside a box.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby GX61 Mark II » Tue Oct 05, 2010 10:05 pm
OEM placement is fine regardless I presume (as stated previously)? i.e. R33 has battery in boot.
GX61 Mark II
Postby CAMB01 » Tue Oct 05, 2010 10:08 pm
If that is factory placement then it should be fine but will find out.
CAMB01
Postby GX61 Mark II » Tue Oct 05, 2010 10:12 pm
There is actually a metal barrier between boot and cabin though, as can almost be see in this pic:
GX61 Mark II
Postby CAMB01 » Tue Oct 05, 2010 10:17 pm
That should be fine
CAMB01
Postby GX61 Mark II » Tue Oct 05, 2010 10:29 pm
Thanks
GX61 Mark II
Postby gurutasker » Thu Oct 07, 2010 10:13 am
GX61 Mark II wrote:OEM placement is fine regardless I presume (as stated previously)? i.e. R33 has battery in boot.
yes an OEM placing is okay, as long as the mounts are secure and you have any exposed positive terminals covered.
:twisted: Wellington's TS Midget :twisted:
gurutasker
Postby cogent » Thu Oct 07, 2010 10:22 am
heck yes booked a car trailer to bring the mx5 up to manfield with.
only like two weeks to go! excited as.
cogent
Postby touge_ae101 » Thu Oct 07, 2010 11:28 am
GX61 Mark II wrote:There is actually a metal barrier between boot and cabin though, as can almost be see in this pic:
so cam, going off the above pic, if i fill all my holes in the rear parcel tray i won't have to worry about making a sealed box? how picky do you get with holes? like do i need to fill in all the little ones where the trim used to attach?
don't really want to cover the whole thing with alloy if i can avoid it, glare in the rear-vision will be a bitch!
touge_ae101
Postby Chelles » Thu Oct 07, 2010 1:19 pm
Put it this way... if battery fluid could get through the hole into the driver cabin then it needs to be seal up. (This is for relocated batteries, not OEM placement). So yup, just fill up the holes that are there that may let any fluid through and you'll be fine.
Chelles
TS Original Member
Postby touge_ae101 » Thu Oct 07, 2010 1:50 pm
how will they need to be filled?will a sealant be sufficient or do they need to welded up? there are quite a few little holes. might just be easier to make a sealed alloy box for behind passeneger seat...
touge_ae101
Postby gurutasker » Thu Oct 07, 2010 4:28 pm
Chelles wrote:Put it this way... if battery fluid could get through the hole into the driver cabin then it needs to be seal up. (This is for relocated batteries, not OEM placement). So yup, just fill up the holes that are there that may let any fluid through and you'll be fine.
Chelles, the concern isn't just about the fluid, but also the fumes associated with a wet cell battery.
Officially any battery located in the 'Cockpit' needs to conform to the additional regulations.
MSNZ Manual definition of a 'Cockpit' is:
"Cockpit" means the structural inner volume of a vehicle which accommodates the driver and any passengers.
In this case I would expect the area between the battery and the drivers cabin to be relatively air-tight (e.g. a firewall between the battery and the drivers cabin on a regular car)
Please be aware of the requirements for a sealed wet cell battery located in the cockpit. For full definitions read the manual or give me a holler.
http://www.motorsport.org.nz/assets/MotorSport-Manual/App-2.02-Sch-A-2010.pdf
gurutasker
Postby cogent » Thu Oct 07, 2010 4:34 pm
Also be aware that just because your car has a factory boot mounted battery, you may need to seal it anyway.
For example, MX5's come with a boot mounted dry cell battery from the factory.
cogent
