Postby GDII » Sun Apr 10, 2016 9:59 pm
Kiwi-Corolla wrote:Quick Saturday mod - I pulled off my old foam EZ Lip and installed this glossy carbon lip in it's place. Was difficult to photograph due to the glossiness but you get the idea :)
Carbon lip looks good. Very shiny but you can tell it's carbon in the photos. Looks way better than my fake CF look vinyl lip haha. I guess my only advantage is if I scratch mine I can just patch it with more vinyl.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby siren676 » Sun Apr 10, 2016 10:00 pm
dskd wrote:well today i had a good crack at killing my fxgt
https://www.facebook.com/RubyRacingNZ/v ... 224325331/
He did warn you about it :lol:
This weekend finally got around to fitting my ssr's
siren676
Postby Al » Mon Apr 11, 2016 6:17 pm
Fitted the stock airbox and intake pipe that I sourced and went to pick a part and raided an FXGT for some trim pieces that were a bit shit on mine.
Al
Postby RS13 » Mon Apr 11, 2016 7:16 pm
Make any difference?
RS13
Postby Al » Mon Apr 11, 2016 7:23 pm
Quieter. Looks tidier. Have to sort out if the vacuum lines are correct. They are the same as they have been for the last 4+ years though.
Al
Postby dskd » Thu Apr 14, 2016 4:51 pm
a bit more of how the pore fx got treated over the weekend http://www.themancave.tv/video/t1RPYIMC7sQ
IM NOT GETTING LESS HAIR IM GETTING MORE HEAD
dskd
Postby GDII » Sat Apr 16, 2016 3:16 pm
Driving home last night and the Starlet decided it would blow a bigger hole in the radiator, steam everywhere :roll:
There has always been a small leak which I couldn't fix and the rest of the radiator was on its way out with rusty bits and the cooling fins disintegrating. This is the small half sized radiator so cooling efficiency was never great and going up hills or high load on the engine for long periods of time would make the temperature rise 2/3rds up the gauge quite often. Occasionally I would use the heater to bring the temps down faster. The odd thing is the temperature will also go down to 1/3rd on the gauge sometimes like going down hills.
The new radiator I picked up this morning from Able Smith Radiators is a full size one so this should help with cooling although a new half sized one would work too but they stopped making them. The differences in this large one is obviously its size, the bottom right mount and the top right mount position and the drain plug location. Everything else is the same. So to mount it all I had to do was find an M8 nut to go on the other end of the right hand top mounting bolt. Luckily there is already a mounting position on the radiator support bar and a hole, just no captive nut. The bottom right mount remains in place on the car, the radiator just sits on the mount rather than having the pin fit into the rubber bush.
Still yet to test it on steep hills and in traffic but I'm sure it will work well now.
1990 SW20 MR2
GDII
Postby sergei » Sat Apr 16, 2016 10:41 pm
GDII wrote:Driving home last night and the Starlet decided it would blow a bigger hole in the radiator, steam everywhere :roll:
Don't forget to change thermostat (and before that flush the coolant).
Postby Leon » Sat Apr 16, 2016 11:31 pm
Engine out of race car, after 10 years, and 94 events.
Pretty smokey, but 190 psi in each cylinder.
Can't complain about that sort of a run out of a $550 wrecker motor. Tough engines those silvertops.
Refreshed engine back in the hole, but not hooked up yet.
Probably get the original engine rebuilt and have it lurking as a spare for the future.
Postby GDII » Sun Apr 17, 2016 5:06 pm
I changed the thermostat a few years ago with a TGP and it's had new coolant a few times over the years.
1990 SW20 MR2
GDII
Postby Kiwi-Corolla » Sun Apr 17, 2016 6:14 pm
Cleaned the wheels.
Kiwi-Corolla
Postby sergei » Mon Apr 18, 2016 4:10 pm
GDII wrote:The odd thing is the temperature will also go down to 1/3rd on the gauge sometimes like going down hills.
This is the reason why I mentioned thermostat. If temperature goes below "normal" after the car warmed up, it suggest that thermostat is jamming up (in semi-closed or open state).
Postby GDII » Mon Apr 18, 2016 4:30 pm
Yeah that's what I got from what you pointed out too but it's done it since new. Might grab another one when I buy some more TGP. It might not have liked getting hot.
The other funny thing is the gauge will go up and down when cornering.... Up when turning left, down when turning right. I'll put that down to a weak needle spring.
1990 SW20 MR2
GDII
Postby Shins » Wed Apr 27, 2016 11:47 am
discovered why the thermostat housing was leaking coolant onto the gearbox - thermostat O-ring was srsly farked
Shins
Postby Kiwi-Corolla » Fri Apr 29, 2016 4:28 pm
Fitted some LED bumper lights in place of the original reflectors:
Kiwi-Corolla
Postby Kiwi-Corolla » Fri Apr 29, 2016 6:02 pm
One more minor mod for the day:
Kiwi-Corolla
Postby Mr. Mainstream » Fri Apr 29, 2016 8:25 pm
Kiwi-Corolla by christ you look after your cars 8O
ive been meaning to ask what product you use to clean your dash etc?
On Topic i got a brand new bushes and fast steering rack put in the ol' Escort.
Crispy, i know your reading this. lets do these tappets :wink:
75 MK2 Ford Escort L 2.1L
Various Others
Mr. Mainstream
Postby Kiwi-Corolla » Fri Apr 29, 2016 9:10 pm
Haha thanks! I don't use any products to clean the interior. Just give it a wipe with a microfiber cloth every month or so and that's it :)
Kiwi-Corolla
Postby GDII » Sun May 01, 2016 2:00 am
Installed a rare JDM El-Glow MR2 badge on the SW20
Plug and play wiring with inverter
1990 SW20 MR2
GDII
Postby Al » Sun May 01, 2016 9:15 am
Hot.
Al
