remember to check your cambelt
Postby Low_Aa63 » Fri Dec 16, 2005 8:34 pm
ahhh so entertaining!
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby Lloyd » Fri Dec 16, 2005 11:10 pm
Heh, didn't take the head off. Take the glow plugs out and crank it over, watch the pretty fountains of water, chuck them back in and eventually get it to fire up. Got a couple fo litres of water out the exhaust, what a mess that was
Postby Muzzie » Fri Dec 16, 2005 11:17 pm
Ahhhh, the joys of non interference motors, and even better - motors without belts!
Muzzie
Regular Poster
Postby Lloyd » Fri Dec 16, 2005 11:17 pm
Chains have their moments too ;)
Postby Muzzie » Fri Dec 16, 2005 11:35 pm
HRT wrote:Chains have their moments too ;)
Who said anything about chains?? :P
*notices HRTs confused look*
Lost yet? :twisted:
Muzzie
Regular Poster
Postby Lloyd » Fri Dec 16, 2005 11:41 pm
Unless you're of the rotary persuasion then I'm not entirely sure what you're meaning
Postby Muzzie » Fri Dec 16, 2005 11:42 pm
HRT wrote:Unless you're of the rotary persuasion then I'm not entirely sure what you're meaning
Nup, not rotary either :)
Piston power yes, but not belt and not chain :)
Muzzie
Regular Poster
Postby Lloyd » Fri Dec 16, 2005 11:43 pm
Lawnmower styles?
Postby Muzzie » Fri Dec 16, 2005 11:43 pm
Lol no, it is a daily road driven car.
Muzzie
Regular Poster
Postby Lloyd » Fri Dec 16, 2005 11:46 pm
So what engine is this then?
Postby Muzzie » Fri Dec 16, 2005 11:47 pm
HRT wrote:So what engine is this then?
No idea of the model number off hand.
Side valve, 4 cylinder, Ford motor.
Muzzie
Regular Poster
Postby ollieboy » Sat Dec 17, 2005 1:06 am
oooh ooh is that called pushrod or something like that.
ollieboy
Postby Ae92typeX » Sat Dec 17, 2005 1:39 am
Muzzie wrote:Lol no, it is a daily road driven car.
what model ford is it?
all the old sidevalve fords Ive seen still have a chain drive for the cam (its short as the cam is just up to the side of the crank, but there none the less), even old 1950's ones like the e83w- which didnt even have waterpumps!
Ae92typeX
Postby Muzzie » Sat Dec 17, 2005 1:47 am
This particular one - is a Prefect, and uses gears.......
Muzzie
Regular Poster
Postby Ae92typeX » Sat Dec 17, 2005 2:36 am
cool, but strange. assuming its an early 50's version (as in the one you posted a while ago), they used the same 1172cc sidevalve as all others of the period- like the e83.
heres a link to a guys rebuild, which clearly shows the chain setup:
http://www.e83w.co.uk/restoration/engine.htm
not saying you are incorrect, just pointing out its a bit weird.
Ae92typeX
Postby Lloyd » Sat Dec 17, 2005 1:21 pm
Old Commodore V6s were gear drives too weren't they?
Postby Ako » Sat Dec 17, 2005 1:43 pm
How old are we talking? All the VN-ish ones were chain driven, sounded kinda... industrial.
Ako
Postby malc » Sat Dec 17, 2005 3:31 pm
oh well, car is back up and running now :D
thanks to my good mate who is a mechanic, got all the parts the next day and came to my house in the evening.
he was saying that most of the toyotas they have seen in which the cambelt has broken, there has normally no damage (or minimal) to valves, pistons and all the other associated parts.
Good ol toyotas eh, they just wont be beat.
FYI the cambelt had only done around 40 thousand ks, which is not a whole heap.
malc
Postby Mr Revhead » Sat Dec 17, 2005 6:41 pm
capri V6 were gears as well
Postby Muzzie » Sat Dec 17, 2005 7:28 pm
The one I posted a while back I don't think is geared. I'd have to check on that bu t from memory his is the first of the chains.
Muzzie
Regular Poster
