turbo altezza, pics up
Postby cr1mnl » Sat Jan 06, 2007 7:45 pm
bluemaumau wrote:interesting idea of the wg controln boost and actin as a bov, has it been done before and worked?
yeah it has been done before and works. how well is another thing but i'm sure adam and si will suss it out. adam has done some rersearch on this kind of setup and is pretty confident it will be ok. I'm more worried about the driveline holding up to adams abuse! will definetly be a damn quick street car!
www.ology.co.nz
cr1mnl
Postby bluemaumau » Sat Jan 06, 2007 7:47 pm
wicked
Postby evil_si » Sat Jan 06, 2007 8:02 pm
i mite not have been clear this isnt my car, just one ive built for a mate
true, it has been done a few times before, and i think i have it sussed as to how, we will soon know when its run.
for those of you that know it that orange KE30 4agte with 171rwkw, also belongs to adam, when the altezza is ready the ke30 will retire as his daily driver
evil_si
Postby NOLAW » Sat Jan 06, 2007 9:23 pm
F**KING AWESOME, good work simon :D :twisted:
NOLAW
Postby eskimo » Sat Jan 06, 2007 11:30 pm
i want one :P
eskimo
Postby sleeektoy » Sun Jan 07, 2007 7:29 am
Awesome work - keep the pics rollin in :)
(i assume the brake reservoirs will have some heat shielding - cos i can see melted plastic happening the second that turbo gets warm)
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
Postby XERO » Sun Jan 07, 2007 10:45 am
I just made happy in pants :oops:
Awesome work man!!! Where did you source the cross member to fit the engine? Is it the same from a GITA Station Wagon?
Altezza RS200 Z Edition
For performance parts :: www.drivenperformance.co.nz
XERO
Postby Silent Knight » Sun Jan 07, 2007 11:18 am
XERO wrote:I just made happy in pants :oops:
Altezza or should I say Lexus came out with a N/A 2JZ anyway so that Xmember should do the trick...
Not sure if this one is the same model though...
Silent Knight
Postby rxtoy » Sun Jan 07, 2007 11:21 am
if the 30 can take the way Adam drives (and its nowhere close to sane) this should be ok for a while, hopefully. it's got to handle better anyway, it wouldn't be possible for it to handle worse :D
i had a good look at this a few weeks ago, looks way better when you're checking out the manifolds in person. top notch work.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby Lith » Sun Jan 07, 2007 11:57 am
I didn't pick up on the wastegate on the pressure side of the inlet setup to control boost - really doesn't sound like a good idea to me, wouldn't it be creating what is normally considered a problem? Ie, an air leak while under boost?
If the thing ever reaches enough pressure that the "wastegate" needs to be opened, then the turbos are still going to behave like they are freeboosting - but the air isn't going to go into the engine. The turbo bearings are still going to take the full brunt of potentially excessive RPM and the air will still get heated quite nicely. Airleaks are a big turbo killer....
Lith
Postby rage » Sun Jan 07, 2007 12:57 pm
if the turbos are appropiately sized, the engine would run out of rpm before the intake wastegate should open. when you think of twin t70s on a stock 3L the spool shud be slow enough to prevent excessive pressures before redline. and if the wastegate does open and vent intake pressure, it will only be for a short time anyway. its bad to overspin a turbo, but id say in this application, if the intake wastegate ever opened, you'd be churning thru the rev range so quick, u wouldnt have a chance to overspin the turbo, and if so, it wouldnt be for long.
rage
Postby flygt4 » Sun Jan 07, 2007 1:00 pm
i suppose the upshot is you'd have the absolute best possible turbo spoolup .
flygt4
Postby evil_si » Sun Jan 07, 2007 1:46 pm
flygt4 wrote:i suppose the upshot is you'd have the absolute best possible turbo spoolup .
:D :D :D :D
not really to worried, as ive previously said diesels free boost, and some run 'pop off valves' on the intake to limit boost
a lot of thought and research has gone into this, and there are other cars through out the world with similiar setup.
as for the crossmemeber its a factory 3sge beams unit with a fair bit of modification as with the sump has also been chopped and changed that a fair bit as well
evil_si
Postby strx7 » Sun Jan 07, 2007 7:30 pm
std internals are good for over 700hp at the wheels, go hard i say.
Postby IH8TEC » Sun Jan 07, 2007 8:43 pm
strx7 wrote:std internals are good for over 700hp at the wheels, go hard i say.
god damn 8O go nuts :lol:
Postby Al » Sun Jan 07, 2007 8:55 pm
700? Thats a bit conservative. There are 1000rwhp+ stock bottom end Supras in the US. 8O
Al
Postby strx7 » Sun Jan 07, 2007 9:33 pm
700 is safe as houses
who really knows what the breaking point of a well tuned stock 2JZ bottom end is. there is a guy on the supra forums with 730RWHP from a 2JZGE with a 2.5mm head gasket and just bolt ons
Postby saft » Mon Jan 08, 2007 6:02 am
Al wrote:700? Thats a bit conservative. There are 1000rwhp+ stock bottom end Supras in the US. 8O
how long after the 1000hp dyno runs do they swap it for another stock bottom end?
saft
Postby JT » Mon Jan 08, 2007 9:22 am
Awesome, thats a decent step up from the 30. There's a 2JZ altezza racecar down here in CHCH, looks and sounds the business! It's for sale at the mo.. http://www.trademe.co.nz/Trade-Me-Motor ... 732298.htm
JT
Postby Lith » Mon Jan 08, 2007 9:23 am
Haha yeah. Those claims from the same country that claim that most VTEC motors can be pushed to over 600whp on standard internals and that the most of the sub 10s drag Skylines in Oz and NZ have basic boltons.
Lith
