flat_0ut wrote:You can take it somewhere for free can't you? Think it was called Salters Oil or something. A few shell stations take it aswell.
Yup, salter cartage, 0800 SALTER I think
Zak wrote:flat_0ut wrote:You can take it somewhere for free can't you? Think it was called Salters Oil or something. A few shell stations take it aswell.
no_8wire wrote:I just tip it in the rubble out the back... or burn it...
Hey oil came from the ground, Im just returning it to its home! Everything wants to go to its home!
solitaire wrote::? You lot are absolutely shocking...
If you pour oil in a wheelie bin you may as well pour it down your sink... it still ends up in the earth... it makes great weed killer because it is highly toxic and kills most things it gets into.
Grrrrrrr! wrote:solitaire wrote::? You lot are absolutely shocking...
Nope, pouring it on the ground is worse, if you pour it down the sink it'll go to the waste treatment plant where i think the systems they use can break some of it down.
Don't pour it down the stormwater drains, that just goes straight into the ocean usually.
Unless you have a spare planet in your back pocket how about we all just take it in for recycling mmkay!
yep your right thanks materollaholic wrote:think you might have mis read what sol was saying there - dont think hes condoning it being poured on the ground.
Ae92typeX wrote:A 'some' above, I collect it and take familys share to the Hazmobile collections usually at 6ish month intervals. However they are reducing what they take, so hopefully its one item that wont be removed from their list.
method wrote:Well if it goes to a landfill it doesn't seep into the earth.
Landfills are lined and fully sealed.
