what do you do with your oil
Postby Zak » Fri Aug 31, 2007 7:40 pm
flat_0ut wrote:You can take it somewhere for free can't you? Think it was called Salters Oil or something. A few shell stations take it aswell.
Yup, salter cartage, 0800 SALTER I think
Zak
Postby neo » Fri Aug 31, 2007 8:42 pm
check out the tips, i thought it was something they needed to provide?
Some of the old BP's might still collect waste oil
neo
Postby mr2_t » Fri Aug 31, 2007 8:53 pm
Oddly enough i went there today, with about 10 4L bottles, and they took the containers as well! :D
Down Roscommon, second on the left after Wiri Station Rd. Its listed as an alternative on the Hazmobile schedule:
http://www.hazmobile.govt.nz/pdf/calendar.pdf
Problem with the hazmobile is waiting for a particular date, then remembering to go...
The problem with socialism is that eventually you run out of other people's money. -Margaret Thatcher
mr2_t
Postby rolla_fxgt » Fri Aug 31, 2007 10:53 pm
I just poor it in our wheelie bin, & they seem to pick it up, i guess the kitty litter might soak it up in that tho, hence why they havent complained yet.
rolla_fxgt
Postby Infinite » Fri Aug 31, 2007 10:54 pm
its great weed killer.
Lots
Infinite
Postby no_8wire » Fri Aug 31, 2007 11:39 pm
I just tip it in the rubble out the back... or burn it...
Hey oil came from the ground, Im just returning it to its home! Everything wants to go to its home!
no_8wire
Postby Infinite » Sat Sep 01, 2007 12:04 am
it can only improve the taste of waitkato water :)
Lots
Infinite
Postby z0ton » Sat Sep 01, 2007 12:39 am
no_8wire wrote:I just tip it in the rubble out the back... or burn it...
It doesnt quite work like that. Its actually illegal to not dispose of oil properly.
z0ton
Postby solitaire » Sat Sep 01, 2007 3:47 am
:? You lot are absolutely shocking...
If you pour oil in a wheelie bin you may as well pour it down your sink... it still ends up in the earth... it makes great weed killer because it is highly toxic and kills most things it gets into.
Come on lads, weve got a beautifull country here, lets keep it that way, oil may of 'come from the ground" but unless your prepared to drill back down to the depth it came from be an adult and dispose of it sensibly :D
AE92, KZJ120, KDJ120
solitaire
Postby ollieboy » Sat Sep 01, 2007 3:52 am
Our local bus company take oil and do something to it and put it back in their buses
ollieboy
Postby Ae92typeX » Sat Sep 01, 2007 10:31 am
A 'some' above, I collect it and take familys share to the Hazmobile collections usually at 6ish month intervals. However they are reducing what they take, so hopefully its one item that wont be removed from their list.
Ae92typeX
Postby Grrrrrrr! » Sat Sep 01, 2007 11:24 am
solitaire wrote::? You lot are absolutely shocking...
Nope, pouring it on the ground is worse, if you pour it down the sink it'll go to the waste treatment plant where i think the systems they use can break some of it down.
Don't pour it down the stormwater drains, that just goes straight into the ocean usually.
Unless you have a spare planet in your back pocket how about we all just take it in for recycling mmkay!
Grrrrrrr!
Postby rollaholic » Sat Sep 01, 2007 2:04 pm
think you might have mis read what sol was saying there - dont think hes condoning it being poured on the ground.
and yes, NZ is bad enough for the planet with our relaxed laws regarding vehicle emissions, lets not make it any worse than it already is :P
Postby method » Sat Sep 01, 2007 2:30 pm
Well if it goes to a landfill it doesn't seep into the earth.
Landfills are lined and fully sealed. There are plenty of heavy metal leachates in landfills from other household items much more toxic than oil that they are trying to keep out of the earth.
Dont pour it down the sink or toilet etc... can cause a fire hazed and is not good for the waste water system, they use bacteria to brake poos & wees down, things such as oil will kill the bacteria.
Dispose of it properly. Or at least bottle it and put it in front of your local council building, they will know what to do with it seeing as they don't provide a good enough service :D
PICS UPDATED DAILY
method
Postby Dell'Orto » Sat Sep 01, 2007 3:13 pm
I'm just saving mine, so that when oil runs out I can be some sort of rich oil baron :lol:
no-one seems to take waste oil round here anymore
Postby solitaire » Sat Sep 01, 2007 5:25 pm
rollaholic wrote:think you might have mis read what sol was saying there - dont think hes condoning it being poured on the ground.
yep your right thanks mate :D - Im bascially trying to say that if you dont get it recycled properly you may as well just poor it into the town water supply... its black and white, your either disposing it properly or your being a selfish inconsiderate wayne ker
solitaire
Postby crazed_silvertop » Sat Sep 01, 2007 7:53 pm
Ae92typeX wrote:A 'some' above, I collect it and take familys share to the Hazmobile collections usually at 6ish month intervals. However they are reducing what they take, so hopefully its one item that wont be removed from their list.
No, oil wont be one of the things they take off of their list - it's the easiest product they receive to get rid of (except for car batteries- they actually get paid for those!!)
They will start to refuse things like DDT, 245T and other nasty 'garden' chemicals.
'89 MR2 AW11 - Silvertop..... fun :)
crazed_silvertop
Postby sergei » Sun Sep 02, 2007 5:44 pm
I am sure they can synthesize whole bunch of stuff (petrol, synthetic oil, or even tar for roads) out of waste oil...
Postby fangsport » Sun Sep 02, 2007 7:49 pm
ask your local roading company. they won't collect small amounts, but will usually recieve it willingly.
fangsport
Postby barryogen » Mon Sep 03, 2007 10:54 am
method wrote:Well if it goes to a landfill it doesn't seep into the earth.
hmm, somehow I doubt that.
http://maps.google.com/maps?f=q&hl=en&geocode=&q=green+island+dunedin&sll=37.0625,-95.677068&sspn=30.875284,59.765625&ie=UTF8&ll=-45.906987,170.409729&spn=0.006614,0.014591&t=h&z=16&iwloc=addr&om=1
This is the tip about 1km from my house... the stream that goes between the two "landfills" is uninhabitable, up stream from this point it is fine and water is drinkable.
Maybe new tips/landfills are sealed, but existing ones are not. This one(public one on the right) is in year 18 of it's 48 year expected life... so 30 years(probably more) from now it'll still be leeching stuff into the stream, and killing anything and everything downstream of it.
barryogen
2ZZ Guru in training
