Quoted directly from the LTSA website...
"Front fog lamps
Front fog lamps illuminate the road ahead in foggy conditions, both at night and during the day. They give off a short, wide beam of light that is designed to shine through the fog, lighting up the area directly in front of the vehicle and helping the driver see the sides of the road better.
Fitting requirements
You may have up to two front fog lamps fitted to your vehicle. If your vehicle already has two front fog lamps fitted as original equipment, you cannot fit a second pair. Fog lamps should be wired so that they can be turned on or off independently of the headlamps.
Front fog lamps must be white or amber in colour. When purchasing front fog lamps, it is your responsibility to ensure they meet approved standards and are designed for that specific purpose. If in doubt, consult a vehicle lighting retailer.
On the road
Fog lamps should only be used when visibility is severely reduced, eg by snow or fog. It is against the law to use fog lamps in clear conditions (day or night) as they can dazzle other road users."
Guess i'll have to turn mine off now...
So all you caldina drivers out there (me included) are law breakers if you drive with them on... better throw the book at us...
Driving a honda is like being in the special olympics. Even if you win, you're still retarded...
