Scottie wrote:Don't they have traction control? Or is that just some Soarers.
That's just some
BlakeNZ wrote:good effort. you car has good power,how were those 60' times?well done again.
flygt4 wrote:probly find you wont make much more power on pump gas with more boost.
2.15 is really good for street tyres, you can't ask for much more in a 2wd.
flygt4 wrote:the track prep in australia is on a whole different level to ours. i've never driven at meremere, but masterton isnt that good. you really want to get there when the comp v8's are running as they lay down heaps of vht for them.
oh and a lot of the dyno's in australia tend to be quite optimistic from what i've seen. i used to read an ozzie car mag a lot and found it hard to believe a lot of the quoted figures in there running standard hardware.
avinesh wrote:naa man was on some cheap street tyres lol an yes the aussi dyno reads lower they use dyno dynamics which read quite low thats what i got my car dynoed on though didnt think it really made 220plus at the wheels till i went to the track an ran a 13.3 was very happy with it mmmmm yea i heard down pipe gives good gains on 1jzs is that rite or a load of crap an also heard cam gears give good gains.....
Lith wrote:avinesh wrote:naa man was on some cheap street tyres lol an yes the aussi dyno reads lower they use dyno dynamics which read quite low thats what i got my car dynoed on though didnt think it really made 220plus at the wheels till i went to the track an ran a 13.3 was very happy with it mmmmm yea i heard down pipe gives good gains on 1jzs is that rite or a load of crap an also heard cam gears give good gains.....
Most turbo cars get good gains by doing the dump pipe- at least on my Skyline I did, it was actually mostly spool and midrange I gained with mine.... but the Skyline comes with a stupidly undersized turbo. The twins on the 1JZGTE at least don't COMPLETELY choke it.
I think I ran 165-169kph with just over 200rwkw in the Skyline, so 220rwkw for ~170kph sounds reasonable. Auto means you can stay on the throttle the whole way - though I gained quite a lot of power to get up to 180kph trap speeds.
avinesh wrote:auto also means more power loss an slower gear change i guess mmmm i wouldnt be too sure about the stock twins man those things are tiny an i mean tiny u would be suprised at how tiny they are..........
lol i run a flat 1.7 60,foot with a auto and thats just driving off the line,pluss i am running 11.1sec on pump gas, you dont need to run race gas unless you are pushing big boost or addvanced your timing.FXGTV wrote:Good work mateMost of the Aussie cars that run good times compared with NZ use two speed autos :S Who says autos are nothing but slush boxes
BlakeNZ wrote:the dump pipes from Marlew engineering in australia will gain you 15rwkW on the 1jz. they are a work of art, not cheap.unique autosports also do a cheaper(but still effective) version. retarding the exhaust cam 6 degrees will gain you 10rwhp,at the expense of low- mid range. most opt for a 4 degree retard which gives about 6rwhp, without losing mid range. the dump pipes get the heat away from the ceramics, and hence they will last heaps longer.the best money you can spend is about 400 bucks AU, getting a stage 1.5 shift kit from MV automatics,it will gain you up to half a second down the strip( equivalent to gaining about 30rwkW!)
also, redline in wellington have front mount intercooler kits available for the jzz30 for about 580 dollars- good value. a big front mount gains 15-20 rwkW on the 1jz.the standard one gets heat soaked on the dyno. it also has a boost drop across the core of about 2psi, compared to a 600x300x75mm bar and plate core having about .5 psi drop at same boost levels.the bigger core flows 496cfm at 28" H20,compared to standard cooler flowing 213 cfm.
heaps more left in your car dude. 13.3@170km/h with minimal mods is hard!!!
