why not use a remote transfer like the Suzuki 4WDs?
would enable any gearbox to be used as well as any location for the front driveshaft
fangsport wrote:why not use a remote transfer like the Suzuki 4WDs?
instead of the transfer box being part of the tailhousing (like Toyota Hilux,Liteace 4WD etc), the Suzuki (and others i guess) use a RWD box with a very short shaft to the transfer box, the shafts for the front and rear diff then comes out of this.TWSTD wrote:fangsport wrote:why not use a remote transfer like the Suzuki 4WDs?
Whats a remote transfer if you excuse my ignorance?
looking at the picture, there wouldn't be enough room. i do think that the 4wd liteace set-up wuold be worth looking in to.Mr Revhead wrote:hmm so if you could find a suitable remote transfer case
you could run a normal 5 speed box, with a short coupling to the transfer, some custom shafts to the diffs and done!
i think you need to look into that!
fangsport wrote:looking at the picture, there wouldn't be enough room.
TWSTD wrote:(well - unless I want to spend 10-12k on a complete custom setup using a GTR box or similar).
AL
Users browsing this forum: No registered users and 27 guests
