MR2SIK wrote:I had a 3 inch downpipe off the turbo, into a 2.5 inch exhaust that headed straight to a hks cannon muffler, off boost and cruising around, it was quiet as, until someone decided to stick their foot in it and rip it off the mounts putting big holes in it, could only afford to replace it with an rps item at the time, now its significantly louder...![]()
Moral is, I had an exhaust system barely a metre long into a quality muffler and it had all of the performance and about a 1/4 of the noise.
even if I manage to get another decent muffler, I still think it will fail a wof just because it looks like a loud exhaust...
Boosted_162 wrote:MR2SIK wrote:I had a 3 inch downpipe off the turbo, into a 2.5 inch exhaust that headed straight to a hks cannon muffler, off boost and cruising around, it was quiet as, until someone decided to stick their foot in it and rip it off the mounts putting big holes in it, could only afford to replace it with an rps item at the time, now its significantly louder...![]()
I have a gutted downpipe into a 3" exhaust, with 2 reso's and a muffler, 4.5" tip and mines damn quiet considering the exhaust is only just over a metre long.
barryogen wrote:whats the difference between the grey and red ones?
IH8TEC wrote:my car is not legal, tested it today at work, 117db at 4k without silencer, 104db at abotu 3500 with silencer
88 at idle with silencer, without at idle is 102, inside the car at 3500 is 92db without the silencer. but i know for a fact when cruising it is quieter.
being around my car at 117db for more than 30sec causes permanent hearing damage, and at 88 after about 2-3hrs will cause permanent hearing damage
so from this, i'm going to try modify the silencer to quieten it down even more without restricting it too much.
HRT wrote:"Note 1 Exhaust system means a pipe assembly through which the engine exhaust gases pass to the atmosphere
and includes some means of sound reduction such as a silencer or resonator."
barryogen wrote:My old car, I pulled hte CAT out, and it made it loud and droney, I put two Coby 19" in it, and it made it a bit quieter, took some of the drone, then put a big oval muffler on it, and it made it damn near silent.
Leon wrote:I tested about 50 cars at two motorsport events, using a dba meter, and as near as possible to the "quick test" method in the book. One car was over (Group A Legacy), two cars were on the limit. All three were f@cking loud.
My standard Sti came in at a whopping 84 as I recall.
Users browsing this forum: No registered users and 22 guests
