SR20de vs. RB20de
Postby xsspeed » Wed Mar 04, 2009 4:37 pm
LS1 is pretty light for a v8 iirc.
anyway please dont cross breed
Buy Frosty's 18rgeu?
RE70 :D
Postby Adamal » Wed Mar 04, 2009 4:59 pm
Actually, get an SR20VE from a late model Primera :D
Postby AE86less » Wed Mar 04, 2009 5:27 pm
xsspeed wrote:LS1 is pretty light for a v8 iirc.
RE70 :D
$&#$% good idea...
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby xsspeed » Wed Mar 04, 2009 5:29 pm
You know it
Forgot about those hubs been f*** busy with work, will try check tonight
Postby RS13 » Wed Mar 04, 2009 5:31 pm
Adamal wrote:Actually, get an SR20VE from a late model Primera :D
Thats' what I was going to say. They're the later VVL engine, 200hp from memory. I've owned plenty of RBs, an RB20DE wouldn't be too bad in a light car, but they're a huge engine, and reasonably gutless. The early SR20s are pretty crap too, 145hp I think?
But yeah, I'd go for as later SR20 as possible, they sorted out the crap oiling system and made plenty more power with the later ones.
RS13
Postby AE86less » Wed Mar 04, 2009 5:56 pm
The reason I thought I'd go SR is cause I've already got cheap access to one that is proven to be good.
The main reason for Nissan vs. Toyota was the cost:power ratio.
But an RE70 does appeal..
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby iOnic » Wed Mar 04, 2009 6:09 pm
They're also numbingly expensive......for the price of an SR20VE you can pick up an SR20DET......and because it actually came out in factory rwd form you have an endless supply of gearboxes/other parts from RWD cars to pick from....oh and they make more power and torque - and are more capable of doubling/tripling those figures if you're game enough.
The only reason I can see for getting an SR20VE is if you raced in an n/a only class or you wanted to be different. Otherwise it's just a can of worms you don't really want to go near unless you own a Pulsar/Primera
Postby johndoe1025 » Wed Mar 04, 2009 6:34 pm
SR20 all the way lol ive heard nothing but bad stuff bout the RB20s
EP82 GT-went mega hard for completely stock, 15.09 quarter, gone now :(
AE111 Levin BZG current! 4AGTE next? you never know....
johndoe1025
Postby iOnic » Wed Mar 04, 2009 6:37 pm
Nothing wrong with the rb20's they're pretty beefy things........they're just old and technology has evolved since their time. It's like comparing a 1g-ge to a blacktop beams 3S
Postby AE86less » Wed Mar 04, 2009 6:56 pm
Is W55 a Hydraulic Clutch?
Or more particularly, would the one in Frosty's RT141 be Hydraulic or cable?
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby RomanV » Wed Mar 04, 2009 7:36 pm
It's a 'mare and a half putting an SR20VE into a RWD setup, courtesy of the distributor being in a PITA spot.
And one with intake, cams, exhaust and ECU made less HP (at a higher rpm) at the wheels than my standard beams 3S.
It would definitely be cool though, would sound good in an older car I reckon.
Also, dont be fooled about an SR20 being any sort of light weight, on account of the block being alloy.
Cant remember the exact figures, but it's a damn beefy block, heavier than a 3S anyway.
Postby thegreatestben » Wed Mar 04, 2009 7:38 pm
AE86less wrote:Is W55 a Hydraulic Clutch?
All w series are hydraulic
thegreatestben
Postby RS13 » Wed Mar 04, 2009 7:45 pm
Yes.. but he doesn't want a turbo. Did you even read the thread? And I fail to see how these engines are "numbingly expensive"..
http://www.trademe.co.nz/Trade-Me-Motor ... 997140.htm
http://www.trademe.co.nz/Trade-Me-Motor ... 312049.htm
http://www.trademe.co.nz/Trade-Me-Motor ... 723848.htm
http://www.trademe.co.nz/Trade-Me-Motor ... 716447.htm
http://www.trademe.co.nz/Trade-Me-Motor ... 926475.htm
I don't think I need to go on? For an extra few hundred, you could have considerably more reliable power, more than enough to do skids and sideways at the track.. add up the cost of getting the earlier SR20DE, modifying it to that power level safely and I'm almost certain it would make plenty more sense to get the VVL engine in the first place, and I'm sure it wouldn't be hard to adapt another dizzy setup onto it.
RS13
Postby iOnic » Wed Mar 04, 2009 7:47 pm
RS13 wrote:never mentioned cost being too much of an issue. Did you even read the thread?
You mean aside from this once? Maybe you should consider reading the thread before asking me if I did ;)
AE86less wrote:I want a fast car but don't want to pay all the extras associated with them at the moment :lol: Student FTL
Postby RS13 » Wed Mar 04, 2009 7:56 pm
I interpret that as him wanting bang for buck, not that hes' broke.
RS13
Postby iOnic » Wed Mar 04, 2009 8:17 pm
RS13 wrote:I don't think I need to go on? For an extra few hundred, you could have considerably more reliable power, more than enough to do skids and sideways at the track.. add up the cost of getting the earlier SR20DE, modifying it to that power level safely and I'm almost certain it would make plenty more sense to get the VVL engine in the first place, and I'm sure it wouldn't be hard to adapt another dizzy setup onto it.
Didn't really want to go into this but ergh what the hell. There's a bit more to it than that mate. Sure the engine may be "cheap" but what gearbox will you use? FWD SR20's (which the SR20VE is) do not bolt up to any RWD SR20 gearboxes....that would be an expensive fix, "adapting another dizzy setup" wouldn't change anything......you would still have a distributor sitting where your firewall is - yes you can use a CAS setup from something else....but instead of running off the cam gear it would be at the back of the head which is another thing to sort out, VVL solenoid needs to be relocated, coolant inlet/outlet will be sitting where your firewall is as well, both manifolds will need to be changed etc etc etc - and you can forget about using any form of factory ecu on it too so there's another $1500+ - you'd be doing well to get change from $5k for a gain of 40hp over a standard sr20de - yep, bang for buck :roll:
There is a reason why there are no Silvias with SR20VE's in them in NZ. Think about it, if it was as easy as dropping it in and changing a coupla things everyone would have done it already? The engine's aren't exactly rare/hard to find ;) They are a good engine and great gain for not much outlay *IF YOU OWN A PRIMERA/PULSAR/OTHER FWD SR POWERED THING* - trying to make one rwd is a costly exercise and you'll still have the average honda leaving you for dust
Postby johndoe1025 » Wed Mar 04, 2009 8:30 pm
be warned RS your talking to a ex SR owner here :P
johndoe1025
Postby iOnic » Wed Mar 04, 2009 8:31 pm
johndoe1025 wrote:be warned RS your talking to a ex SR owner here :P
several SR's ;) of every sort :lol:
Postby FLAWLES » Wed Mar 04, 2009 9:52 pm
rather than every one moaning about this
lets stop and look
think
wonder
lmaybe you should throw some money at the dirty 4k, always had a soft spot for them
cam
some nice side daft webers. 3k head or something
be a bit more fun then and still cheap
plus with the 4k you will be able to pull heaps of hot sluts, cause they will no doubt think that you have a rotor
win win man win win
FLAWLES
Postby iOnic » Wed Mar 04, 2009 10:20 pm
FLAWLES wrote:plus with the 4k you will be able to pull heaps of hot sluts, cause they will no doubt think that you have a rotor
win win man win win
this man wins
Users browsing this forum: Google [Bot] and 23 guests
