AE111 Differences?
Postby BZR4AGE » Thu Mar 12, 2009 8:11 pm
the only MAJOR difference is if you intend to put coilovers in it.
non s/s coilovers are relatively cheap....but superstrut, expect to pay at least 3-4x the price...or if you are lucky, second hand ones from trademe which will most likely need rebuilding.
BZR4AGE
Postby TRD_ZERO » Thu Mar 12, 2009 8:12 pm
Dell'Orto wrote:Screw that, Super Strut is great. Sure the turning circle is a bit average compared to non s/s, but the braking is awesome and they have a really good feel on the road. Plus to replace the parts that wear out is not really that spendy anymore.
+1
and if u get a non facelift with superstrut it mostlikely has the lsd.
Previous:
TRD_ZERO
Postby Kittah » Thu Mar 12, 2009 8:23 pm
What is the main benefit of Super Strut suspension, in simple and realistic driving terms? I know it "minimizes camber change through out the travel of the suspension" but what does that mean in driving effect? I'm not terribly clued up on this sort of thing, I must admit :P
I do like to drive out in the Waitakere Ranges for example, where the roads and corner can get quite rough on suspension. Does Super Strut have any effect on changing your shocks and springs?
Kittah
Postby Dell'Orto » Thu Mar 12, 2009 8:55 pm
In simple terms, it holds the road better, SS cars I've driven feel quite planted vs non ss. Changing shocks is easy as.
Postby xsspeed » Thu Mar 12, 2009 9:26 pm
+1
+1 Almost certainly will have lsd for ae111 prefacelift superstrut (ie BZG with SS trans code will be C56-04C - yet to see one without it)
Postby Stott69 » Thu Mar 12, 2009 9:54 pm
ive been for a few kanings around the ranges in my car, BZR S/S 6 spd. handles awsome, had a mate in a V6 wrx wagon, chase me over the paituia track, he ran out of brakes comeing up behind me at 170k into a corner, mine were fine. So deffenetly goes well. Horror storys tho, when the extra joints wear out the struts are able to turn and the ass ends tends to get slippery
Image jzs147 Aristo money pit
Stott69
Postby barryogen » Thu Mar 12, 2009 10:09 pm
Stott69 wrote:V6 wrx wagon
A what?
barryogen
2ZZ Guru in training
Postby Dell'Orto » Thu Mar 12, 2009 10:11 pm
Version 6 ;)
Postby Stott69 » Thu Mar 12, 2009 10:24 pm
Dell'Orto wrote:Version 6 ;)
Yes I have bad short hand :oops:
Stott69
