Results from test day @ Puke :(
Postby cat007 » Sun Apr 19, 2009 11:50 am
Bazda wrote:
cat007 wrote:
Bazda wrote:brakes possibly over heated.
When I ran mitex pads they over heated in 3 laps. The pads started coming off the backing plates.
What pads are you running now?
Oh I just did a custom brake install lol
Put on some big 300mmx30mm rotors and wilwood calipers.
But feel as if I need to go to 330mm rotors next.
330mm is pretty massive - how much do you weigh in at?
Postby molex » Sun Apr 19, 2009 1:03 pm
If you're serious about dropping your laptimes have a look at RaceChrono which connects to a bluetooth GPS device and provides all sorts of very accurate speed/timing info. You can even match the data recorded with your in car video.
Here's a trace from a lap in my bog standard starlet, think this was the second time I'd been:
The GPS was a huge help for me, last time I had a clean test day I got down to pretty much exactly your laptime running 6psi of boost
molex
Postby mjrstar » Sun Apr 19, 2009 1:08 pm
mr no fear integra is right, i recall him at superlap in his evo3 exiting ford mountain on the grass... he still kept it pinned and managed a good time...
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Dell'Orto » Sun Apr 19, 2009 1:14 pm
Looks like you had a shitload of fun regardless...thats what its all about at teh end of the day :D
Real keen to try out Puke, but my car wont have enough grunt for the back straight.
Postby cat007 » Sun Apr 19, 2009 1:18 pm
molex wrote:If you're serious about dropping your laptimes have a look at RaceChrono which connects to a bluetooth GPS device and provides all sorts of very accurate speed/timing info. You can even match the data recorded with your in car video.
I have BBTracker for my blackberry but its pretty crap
Postby cat007 » Sun Apr 19, 2009 1:19 pm
Dell'Orto wrote:Looks like you had a shitload of fun regardless...thats what its all about at teh end of the day :D
bah - anyone can drive fast in a straight line. The straight's only there so there's a little break between corners :P
Postby QikStarlie » Sun Apr 19, 2009 4:39 pm
keen to see some video footage of the day .
QikStarlie
Postby cat007 » Sun Apr 19, 2009 5:00 pm
QikStarlie wrote:keen to see some video footage of the day .
Please hold :)
Postby cat007 » Sun Apr 19, 2009 9:14 pm
Postby Bazda » Sun Apr 19, 2009 10:02 pm
around 1100kg. But FWD uses alot of front bias and only a tiny bit of rears!
Postby cat007 » Sun Apr 19, 2009 10:06 pm
Why does FWD matter what the bias is?
Postby postfach » Sun Apr 19, 2009 10:13 pm
As a guess - because all of the weight is over the front wheels, and when you brake weight shifts forward, therefore massive amount of weight at the front and basically nothing at the back = rear brakes do nothing at all, front brakes do all the work.
postfach
Postby Bazda » Sun Apr 19, 2009 10:19 pm
All cars matter what the bias is!
And yes what postfach said is correct.
My rears barely work, I recon they are on 10-20% rears.
Postby cat007 » Sun Apr 19, 2009 10:22 pm
haha - I know that - I meant why more for FWD as opposed to RWD or 4WD
Postby MikeMan » Mon Apr 20, 2009 11:51 am
A higher percentage of the weight is over the front axle in a FWD compared to anything RWD/AWD.
In the Mini I used to crew on we had 10.5" (268mm) discs with Willwood Superlite 4 pots on the front. Standard drum mechanicials on the back with finned drums (Minifins). A tilton proportioning pedal box at max front (IIRC 75% front, 25% rear) and still ran a 80% block valve inline with the rear brakes to stop lockups. :)
Mind you static weight distribution was something like 79/21 F/R with a full tank of fuel as we ran a beam rear end on it. :)
MikeMan
Postby KinLoud » Wed Apr 22, 2009 2:18 pm
Heavily edited video from my incar camera. Started with about 1 hour, left the more interesting bits.
LOOK FOR
- cressida spinning in front of me at Castrol
- me catching up to Honda S2000 under brakes at both ends of the track
- at the very end of the clip... one of the Slipway Boys (Evan I think in 1UZ powered MarkII) spinning behind me at castrol (look in the mirror).
http://www.youtube.com/watch?v=b3QGe7MyU3c
Ken
Auck
021 408 863
Postby cat007 » Wed Apr 22, 2009 2:39 pm
KinLoud wrote:Heavily edited video from my incar camera. Started with about 1 hour, left the more interesting bits.
LOOK FOR
Awesome video!
Postby petrolhead » Wed Apr 22, 2009 5:37 pm
awesome vid. seeing a RAV4 cracked me up
petrolhead
Postby Dragger_Dan » Wed Apr 22, 2009 5:45 pm
Just got myself that RaceChrono for my N82 with built in GPS. I'm going to try it out at the street sprint this weekend and see how accurate the N82 GPS is when compared with the official timing. An awesome toy for free for your symbian/windows mobile phone.
Dragger_Dan
Postby cat007 » Wed Apr 22, 2009 5:49 pm
Dragger_Dan wrote:Just got myself that RaceChrono for my N82 with built in GPS. I'm going to try it out at the street sprint this weekend and see how accurate the N82 GPS is when compared with the official timing. An awesome toy for free for your symbian/windows mobile phone.
SUCKS that there's no blackberry support :(
Users browsing this forum: No registered users and 48 guests
