Dell'Orto wrote:How tall? I'm 6'1ish, and fit them fine...though are you meaning with harnesses?
You're also made 3/4 width
strx7 wrote:that the harness holes are high enough up that they dont compress you spine when you pull the harnesses tight
Looonie wrote:strx7 wrote:that the harness holes are high enough up that they dont compress you spine when you pull the harnesses tight
On this note, can anyone recommend some seats that aren't made for midgets who had their legs cut off at birth? Every single race seat I've sat in, the harness holes have been below my shoulders... I just figured it was something I'd have to live with, but now I'm a little worried...
strx7 wrote:Bazda wrote:If you can find Racepro they are also really well priced.
I got mine for like $350 each from Repco on special!!!
racepros are OK if you are small, if you are a taller person racepros are too small
Bazda wrote:
http://www.racepro.co.nz/seatdimen.htm
Looonie wrote:I'm only 6'6"... fairly substantial build too
TTEETT wrote:Looonie wrote:I'm only 6'6"... fairly substantial build too
You are a giant! Maybe look at basketball instead of motorsports![]()
If you are local you are more than welcome to try my seats out, maybe at a Toyspeed Trackday or meet, they are very generous![]()
GL
DexGT wrote:With racetech seats being made here they can make them to suit. A guy in the car club had one made with the seat belt holes higher for this very reason.
Looonie wrote:So did some quick measuring again, looks like harness holes being about 690mm high is what I need...
Racetech 4000WX looks to be about 2cm too short, can't find the specs for the Sparco EVO seats.
85AW20v wrote:Looonie wrote:So did some quick measuring again, looks like harness holes being about 690mm high is what I need...
Looks like Racetech now do a seat for tall and tall and wide people - RT4009THR or WTHR. http://www.racetech.co.nz/racetech.shop/index.php?main_page=product_info&cPath=65&products_id=422. Says the harness holes are at 71cm from the base so might be OK for you. It's measurement G that you need to check. There are others as well apart form the one I've linked to.
Looonie wrote:I should probably get along to Speedshow and visit the Racetech stand, hopefully they have one there, although I'd hate to think what the cost of it will be.
