Postby matt dunn » Sat Sep 14, 2013 6:27 pm
Boosted_162 wrote:Replaced the sparkplugs in the Legacy in 3 hours. Not bad I thought considering I have never worked on a boxer engine before! It sucked hard tho :lol: and now my back is $&#$%.
Drives much nicer now tho :D
ABS or NON ABS model,
ABS makes the job worse.
Postby Boosted_162 » Sat Sep 14, 2013 7:04 pm
ABS, I found the powersteering lines were more annoying than the ABS! And the fact the back 2 cylinders have almost no clearance between the coilpack and chassis rail. Still rather the 6 cylinder than the turbo model :lol:
Postby crispy'86 » Sat Sep 14, 2013 7:40 pm
Fitted another slightly tidier front bumper on the cough integra cough, prepping it for sale. Used my dent removal kit for the first time, did a great job
crispy'86
Postby Bling » Sat Sep 14, 2013 9:32 pm
What dent kit you got?
Installed engine into escort, fitted exhaust, fuel tank, grill, headlights, other bits and bobs. Gearing it up to sell /burn if it doesn't sell.
Postby Dell'Orto » Sat Sep 14, 2013 9:54 pm
Put the new pistons onto the rods, then assembled the short block for the sedan today. Need to change the cam bearings though :?
Postby crispy'86 » Sat Sep 14, 2013 10:56 pm
BZG|Bling wrote:What dent kit you got?
It's a topmaq set bought on clearance a few months ago with dollys, different shaped mallets etc. Worked in the space I needed it with a suitable result
crispy'86
Postby Brick » Sat Sep 14, 2013 11:02 pm
put petrol in it
Brick
I know Kung Fu
Postby Bling » Sat Sep 14, 2013 11:42 pm
Ah, thought you might have a suction cup kit sort of deal. Hammers I got sussed.
Postby loudstealthGT-Four » Sun Sep 15, 2013 12:52 am
Made up brackets to hold new wastegate actuator
Also put turbo back on, and almost everything else. Car is outside so had to work between rain/hail showers. Just need to put a couple bits of intercooler piping back on, give it an oil change then double check i've connected everything up properly, already for Clubsport Sprint in the afternoon.
loudstealthGT-Four
Postby 2jayzgte » Sun Sep 15, 2013 12:44 pm
Drove car.Did my early morning Alexandra Rd through Roseneath Run.
Came to the conclusion F**K my car still goes like a cut cat loved every minute of it.
2jayzgte
Postby Adoom » Sun Sep 15, 2013 1:21 pm
Installed my twin strap extinguisher bracket. Old one was a bitch to get off because the gearbox was in the way.
Installed the new on on top of the transmission tunnel.
Adoom
Postby Mr Ree » Mon Sep 16, 2013 10:22 am
Removed all my intercooler piping, and test fitted my brand new GTE cam covers/coil covers, and FFIM to see how much tidier my engine bay looks.
The answer? $&#$% HEAPS!!!
wak thud gush!
Mr Ree
Postby crispy'86 » Mon Sep 16, 2013 1:57 pm
BZG|Bling wrote:Ah, thought you might have a suction cup kit sort of deal. Hammers I got sussed.
Never thought the suction cup would work on deep dents like i had.
Anyway went and roughly matched a spray can to paint the car with, man metallic silver is a b@&*h to match. Don't have time to get spray store or the other places to match up a can.
crispy'86
Postby steroidcontaskie » Mon Sep 16, 2013 8:46 pm
Mr Ree wrote:Removed all my intercooler piping, and test fitted my brand new GTE cam covers/coil covers, and FFIM to see how much tidier my engine bay looks.
Hey Dude,
How are you running the coils? Did you go full aftermarket or do something like a 7M COP conversion?
Edward
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby Mr Ree » Mon Sep 16, 2013 8:58 pm
Im going to be running an ECU for the GTE, and the coils/ignitor from a VVTI GTE, and deleting the dissy cap/leads, but retaining the dissy base for the cam and crank angle sensors.
Ill upload some pics to a host site, and then put a couple in here so you can see how much tidier it is with the GTE cam covers, and without the big mess of dissy cap/leads lol
Down the road, if I end up getting a stand alone, then I will use the CAS from the 7MGTE as its even lower profile than the billet cap I have on my dissy base
wak thud gush!
Mr Ree
Postby 1I1 » Mon Sep 16, 2013 9:04 pm
Removed old oil cooler on Friday night/fitted new one Saturday morning. Probably should have changed the oil at the same time, but that can wait till this weekend. Still need to organise a wheel alignment before the weekend too. Then time to go do sweet 20v skids at Manfeild :)
TRD Clicky >>Here
1I1
Postby Stott69 » Mon Sep 16, 2013 9:18 pm
Mr Ree wrote:Im going to be running an ECU for the GTE, and the coils/ignitor from a VVTI GTE, and deleting the dissy cap/leads, but retaining the dissy base for the cam and crank angle sensors.
Why the VVTI coils and ignitor?
Stott69
Postby crispy'86 » Mon Sep 16, 2013 9:36 pm
Checked out the corolla, sorted the fuel leaks and some wiring issues. Wired in the oil pressure gauge, cranked it over and tried starting only to have the starter die. Closed up garage, came inside and had a shower. Will check the starter tomorrow or put one of my spares on
crispy'86
Postby JZCrazy » Mon Sep 16, 2013 9:58 pm
Got the chiller box on the Toyoace working and started stripping the sign writing off.
JZCrazy
Postby Distrb » Mon Sep 16, 2013 10:09 pm
drove it as fast as i could at shelly bay sprint.
Distrb
Regular Poster
Users browsing this forum: No registered users and 30 guests
