Noisy exhaust tests coming
Postby barryogen » Wed Jul 05, 2006 3:51 pm
Mr Revhead wrote:where the exhausts splits to go to the seperate mufflers theres a valve.
at low flow the gases go to the drivers side muffler
when u nail it the l/h one opens up.
thats why on a cold day you can see the gases coming out of one side only
I believe that this also helps with fuel economy in the lower rev range, as it helps it scaveng better than if it was open.
Stealer Of Souls wrote:But a number of euro cars now have valve systems in the exhaust which restrict the flow during cruise in order to reduce the noise output.
If they let people retro fit these sort of things
http://www.hyperflow.com.au/techaes.html
then it won't be so bad.
According to my local cert guy, they're not illegal as long as you install them without the switch, so leaving them computer controlled.
barryogen
2ZZ Guru in training
Postby Stealer Of Souls » Wed Jul 05, 2006 5:58 pm
I wondered as much. I suspect that it would end up as one of those "he says yes, and he says no..." type affairs. But really. What's the fun without the switch... :P
'86 AE85.5 Levin
Stealer Of Souls
Postby no_8wire » Wed Jul 05, 2006 9:37 pm
just make it a hidden switch... 8)
no_8wire
Postby matt dunn » Thu Jul 06, 2006 1:37 am
no_8wire wrote:just make it a hidden switch... 8)
Or if you run a decent aftermarket ecu you could swith them, RPM, TPS or boost dependant.
I am pretty sure that the AE101's dont have them.
How about posting up a picture that you do off your EPC mr Revhead.
All ae101 20V's or just some facelifts etc etc?
And 95 decibels is the NZ wide noise limit at Motorsport NZ events,
so that's basically all circuit cars are 95 or less.
They are measured a a much greater distance than those spec's posted earlier.
Matt
Postby Mr Revhead » Thu Jul 06, 2006 10:51 am
its not a controlled valve, just a flapper valve thats moved by pressure.
the whole middle section if the exhaust is sold as one piece.
having said that i am trying to recall how i know that :?
Postby Stealer Of Souls » Thu Jul 06, 2006 10:56 am
I think you're right.
I was behind a AE101 on the way home last night. And sure enough, the exhaust was definitely only coming out one tailpipe...
As for the hidden switch. Like all hidden things, it's a pain to get at in a hurry... It's not really an issue. 99.999999999% of the time you'd just leave the valve in auto anyway...
I must see if my WOF guys will let me have one...
'86 AE85.5 Levin
Stealer Of Souls
Postby sergei » Thu Jul 06, 2006 10:58 am
I had stock AE101 exhaust cut off just right at Y connector and I have not seen anything special in there, just a normal Y joint (could see it through with mufflers unbolted)...
Postby Mr Revhead » Thu Jul 06, 2006 11:27 am
ae101 20v?
what would have happened there is the power of the mighty 20v has blown the valve completly away.
so it must be due to flow of the mufflers then as the flow is definitly split.
but when you look at the two mufflers its easy to see the difference.
however i have definitly seen a model of chaser/aristo/barge etc that has an exhaust valve on that by passes the rear muffler.
looked factory too, wasnt a bling muffler
Postby sergei » Thu Jul 06, 2006 11:58 am
ofcourse it is allmighty AE101 20v, the fastest road car ever produced ;)
Postby 86_rolla » Thu Jul 06, 2006 12:06 pm
:roll:
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby Jebus » Thu Jul 06, 2006 12:17 pm
sergei wrote:ofcourse it is allmighty AE101 20v, the fastest road car ever produced ;)
On surpassed by an AE92 FXGT with a 20V conversion of course :P
Jebus
Postby Lanius » Thu Jul 06, 2006 1:18 pm
Which is surpassed by a lighter AE82 with 20v conversion? :P
Lanius
Postby AceSniper » Thu Jul 06, 2006 5:02 pm
pritty sure blacktops have a valve but its built into the muffler, while silvertop just use two mufflers with verying flow rates
AceSniper
Postby snwtoy » Thu Jul 06, 2006 9:07 pm
Caldina has a valve built into the muffler which closes off one of the twin pipes at low rpm. I removed my actuator and jammed it open..
snwtoy
Postby 10k 20v » Fri Jul 07, 2006 12:54 am
my old **cough** camry vzv32 4vz-fe **cough** had a valve at the rear muffler.
10k 20v
Postby GTRgod » Fri Jul 07, 2006 8:10 pm
I think my GTR would just pass, but having the same noise for bikes is abit ghey. Having a semi-loud exhaust on a bike is a good way to make sure you are noticed by other motorists...
-and $100 minimum is just a f*cking joke~~~
"Arguing on the internet is like competing in the special Olympics, even if you win, you're still retarded."
http://toyspeed.blakjak.net/profiles/profile.php?id=91
GTRgod
