Why you dont drive your racecar to the track... with VIDEO!!
Postby mr_monkey » Wed Aug 02, 2006 10:31 pm
Damn dude! that sucks balls!
I reckon you should put the motor into an AW11. 8)
Or maybe v6 then turbo an SW and put that round the track.. :wink:
-Nathan
mr_monkey
Postby RS13 » Thu Aug 03, 2006 12:03 am
Unlucky.
As my old manager once said, its' not a problem, its' an opportunity! I quite like the look of the early Carinas, I would personally reshell it, they're turning out to be a great alternative to other (heinously overpriced! :wink: ) RWD Toyotas!
RS13
Postby RedMist » Thu Aug 03, 2006 8:48 am
Looking at the video...
You really didnt have a hope of getting out of that one.
Last time I was in a circumstance like that I ended up running the Bunderson off a very steep bank.
All okay though, a tree stump stopped me at about 40kph.
And that camera setup, clever. I'll have to replicate it in my rally car!
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby KinLoud » Thu Aug 03, 2006 2:06 pm
Yeah the video camera has been great (not just for catching this particular "moment") I guess I could post up some more of my racing video's.
I have one wideangle rear view mirror for me and one for the video camera. I'm still fine tuning it's location.
I got the mirrors from supercheap for $10 each. they have a clip to fasten onto the existing mirror - I made a bracket for the video camera mirror and it mounts onto the main hoop of the rollcage.
Ken
Ham
021 408 863
Postby SkylineObsession » Thu Aug 03, 2006 2:16 pm
KinLoud wrote:I will post up some more of my racing video's.
There, fixed that sentance for ya. ;)
SkylineObsession
Postby neo » Thu Aug 03, 2006 3:20 pm
KinLoud wrote: I made a bracket for the video camera mirror and it mounts onto the main hoop of the rollcage.
If only you'd got around to copying my mount, your cameras all over the show!...
Im sad to say, but the blur after the bang was a great touch!
neo
Postby matt dunn » Fri Aug 04, 2006 12:03 am
I have made a mount for my camera too, although it's a digital camera not a video camera.
Still, 6mp camera abd a 1gb memory card gives 15mins of continous video.
Only problem is it comes out in .mov or quicktime format, and the program I have to convert it looses so much quality.
I had to relocate it as it blocked my rear view for racing, but the new nount is all go and will be in use at the clubday on sunday.
Matt
Postby RedMist » Fri Aug 04, 2006 9:40 am
Anyone got a pic of their camera mount?
RedMist
Postby KinLoud » Fri Aug 04, 2006 10:34 am
Full length video of the race is now up (with a bit of editing while they took my car off the track). http://www.youtube.com/watch?v=ZdcEjLdp2LE
I folded up a box out of aluminium. I made a cardboard prototype first to check everything would fit ok. It has an open back and a hole in the front for the lens to look through. It has strips of high density foam to hold the camera. The box bolts to a braket on the X part of the rear stays of the rollcage. The mirror bolts to the top of the main hoop.
The camera slides into the box through the open back and looks out the hole in the front.
PICS of camera mount here viewtopic.php?p=490134#490134
Neo - you comment of the "camera moving around" - it doesn't move at all. But what appears to be movement is actually the steady shot/anti shake function of the camera. The lens picks up a slightly wider view than it shows on the screen. If the camera shakes the frame of the picture is moved to reduce the shake shown on the camera. It does a good job as I have tried it with the anti shake function off.
Ken
Ham
021 408 863
Postby Dragger_Dan » Fri Aug 04, 2006 4:39 pm
Wow, that little green starlet was pretty quick off the line, what has it got in it?
Dragger_Dan
Postby KinLoud » Fri Aug 04, 2006 10:59 pm
Bigport 4age... power to weight ratio = good.
Ken
Ham
021 408 863
Postby RedMist » Sat Aug 05, 2006 9:47 am
I must say, hats off to your composure. I think I would have done more than just throw my gloves off.
In regards to your next car selection... you currently seem quicker in braking and corner exit but well down on power to weight. You havent thought about going KP yourself?
RedMist
Postby Mr Revhead » Sat Aug 05, 2006 10:35 am
what does that carina weigh? i recall you saying a figure that impressed me
Postby KinLoud » Sat Aug 05, 2006 5:49 pm
Yeah - been thinking about a Starlet.
With the 4age Bluetop and T50 and cage - 960kg, 120hp if I was very lucky (300,000km engine)
With the 3sge and W57 and cage - 1020kg, 180hp
That Starlet was very quick off the line but I had faster lap times probably due to setup and experience. But faster lap times doesn't mean you will beat someone with a faster start!
Ken
Ham
021 408 863
Postby RedMist » Sat Aug 05, 2006 6:06 pm
KinLoud wrote:Yeah - been thinking about a Starlet.
Ken
Ham
021 408 863
Ken, why not Silvertop or G13 twin cam a KP. Certainly a cheaper option to get good eventual HP from it. My silvertops were 122 and 123 HP at the wheels, through a RWD stlye transaxle, and you can pick one up for under $500.
It certainly looks as if you know how to setup your car well as your lines were all over the place in an attempt to get past that blue (starlet?). You had braking, cornering and exit all over him. He just appeared to have a little more power.
I'd hate to see just how fast the Lancer RS rally car is. I think you'd give me a good run for my money!
RedMist
Postby Mr Revhead » Sat Aug 05, 2006 6:57 pm
I'd hate to see just how slow the Lancer RS rally car is
corrected :wink:
Postby KinLoud » Sat Aug 05, 2006 9:22 pm
In the video the blue car I am chasing is a civic (dammit).
The starlet is green... It gets away for a couple of laps then I pass it going slow due to it exhaust falling off - you can see the sparks coming off from underneath - hah.
Yeah - Keep to get the carina back on the track but I have been thinking about building a new racecar for about 2 years.
A mint starlet would probably do the trick. Engine... blacktop, altezza 3sge, maybe 2zzge! (mounting and bellhousing problems would need to be sorted). Gearbox - depends on cost/weight/availability factors... Hmmm I wonder what people will do when all the T50's are broken?
Ken
Ham
021 408 863
Postby Adamal » Sat Aug 05, 2006 9:50 pm
After having a chat with RedMist, he informed me that the 2ZZ is a bit of an unreliable engine. Has anyone had experience with these having problems? Interested to find out
Postby RedMist » Sat Aug 05, 2006 9:55 pm
Adamal wrote:After having a chat with RedMist, he informed me that the 2ZZ is a bit of an unreliable engine. Has anyone had experience with these having problems? Interested to find out
Ummmm... don't quote me on quoting that. As I was simply quoting another Toyspeed member. It was 10k20v (Ewan).
RedMist
Postby Adamal » Sat Aug 05, 2006 9:59 pm
Ok, sorry about that. :)
Does anyone have any experience with their reliability?
Users browsing this forum: Bing [Bot] and 8 guests
