ae92 gtz common problems?????
Postby Lloyd » Sat Apr 04, 2009 9:25 am
Bazda wrote:Even better jack the car up, leave it in neutral turn one wheel and see what the other wheel does. If the other wheel turns the same way then its most likely LSD, if it turns the opposite its open an open diff.
Do not put it in gear to do this test as most people do and think they have a lsd, of course both wheels will turn the same way! or how else would the car drive fowards.
That car did have one, I used to own it too.
Postby Quirky » Wed Apr 08, 2009 10:53 pm
To avoid opening a new thread.
The gearbox in my car seems to be very short...
1st gear = 30kph
2nd = 70
3rd = 110-120
Roughly 7000rpm for each change.
Does make for quick acceleration but cruising along at 100kph I'm doing nearly 4000rpm in 5th. Also have to change gears more often. I think the car would be faster if it had longer gears, definitely has the torque to go through longer ratios.
I remember on my old blacktop 1st gear was like 70 or 80kph at over 8000rpm...hur
edit, forgot the question:
Which gearbox would I most likely have?
Hello There
Quirky
Postby Mr Revhead » Wed Apr 08, 2009 11:33 pm
i think you should start a different thread.....
something weird
and 70k in 1st? not with a C series box...
start a new thread with all the details, ie whats the car, engine etc
Postby ~SlideWays~ » Thu Apr 09, 2009 10:15 am
Quirky wrote:To avoid opening a new thread.
1st gear = 30kph
2nd = 70
3rd = 110-120
Very short! My GTZ will be almost off the clock (180) at the end of 3rd at 7800rpm-ish.
Can't be a standard 4age box either because our standard ae101 does 3000rpm at 100k.
Old ae86 did 3700rpm@100kph though, but that was with 4.3:1 diff.
~SlideWays~
Postby Quirky » Thu Apr 09, 2009 12:11 pm
Ive just emailed the bloke that sold the car to me, see what gearbox is in it. Im very curious now. It may not be standard, but its been able to withstand pretty much 7 months of abuse which includes many drag runs, probably 30 drag races and each time I've warmed up the tyres very nicely. Yay for weekend drag venues. Costs only $28 to race too, worth every cent!
But at the end of the drag strip, im finding myself at the end of 4th gear, about to change into 5th...so really short gears, and I'm only doing about 95mph at the end of it.
Hello There
Quirky
Postby jakesae101 » Thu Apr 09, 2009 4:58 pm
mines like 100-110 in second
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Mr Revhead » Thu Apr 09, 2009 5:32 pm
Quirky wrote:Ive just emailed the bloke that sold the car to me, see what gearbox is in it. Im very curious now. It may not be standard, but its been able to withstand pretty much 7 months of abuse which includes many drag runs, probably 30 drag races and each time I've warmed up the tyres very nicely. Yay for weekend drag venues. Costs only $28 to race too, worth every cent!
yeahs sounds stupidly short, no surprise it hasnt broken though, they are quite tough, its just the syncros that die
Postby Quirky » Thu Apr 09, 2009 5:40 pm
~SlideWays~ wrote:
This is exactly like my car 3700-3800rpm at 100kph.
Lucky i only drive around town cause the exhaust noise at that speed is nauseating .
Hello There
Quirky
