http://page10.auctions.yahoo.co.jp/jp/auction/m98173872
Like its been said before just do basic brake and suspension mods and just learn to drive it quickly (on the track
rollaholic wrote:dnalunchie wrote:they thing to remember about the blacktop engine is once you have the basic Intake exhaust and cams everything else is going to cost big money.
the first 30hp. cheap
the next 30hp.... heaps
doubling the factory output is cheap?!
honda do better NA 4 cylinder engines than any other manufacturer i can think of by a long stretch, its simple really(not counting bikes
if you want straight line speed, you have the wrong car. if you want to go fast round corners well... theres alot more stuff above power on the list of things that help.
dnalunchie wrote:
couldnt agree more, the sensible person buys a Type R (like the one I brought lol)
I see/hear this alot.
Sorry to be so finicky but isn't brought past tense for bring and bought past tense for buy.
Shrike wrote:Changing to a
7age
2zz
1zz
2azfe
Etc all toyota motors that would be fine
(I think the 3s/5s engines are heavy pigs so im bias)
But I get the reasoning for the honda engines there easy to get and cheap to get parts for
jacobrjett wrote:Personally I admit to myself that while its easy to compare our levins to integras... we should know the Type R is a lot faster...![]()
but hey - at the end of the day - at least we dont drive a honda
Shrike wrote:jacobrjett wrote:Personally I admit to myself that while its easy to compare our levins to integras... we should know the Type R is a lot faster...![]()
I never got beaten by a honda even a typre R
Not sure if that was because every honda driver in one that I came across cant drive or what but in saying that my engine wasnt stock and my car was quite light
On another note I measured up my 25det neo engine last night and if I cut the fire wall and made custom front mounts it would fit if I sat it 100mm back in the car :p
But would be so front heavy and im not that crazy
dnalunchie wrote:Shrike wrote:jacobrjett wrote:Personally I admit to myself that while its easy to compare our levins to integras... we should know the Type R is a lot faster...![]()
whats your car and mods?
Mr Ree wrote:Shrike wrote: and tbh I drive like a manic haha
Only on the track, I hope?
Shrike wrote:I never got beaten by a honda even a typre R
Lith wrote:Shrike wrote:I never got beaten by a honda even a typre R
Honda vs Toyota drags started after conversations starting like that to settle that kind of thing, general conclusion is when you hear about conclusions formed in illegal street racing with no redlighting, no set race distance, unobjective race results (the amount of times I've seen where both people involved are adamant they won) any result you hear is very much to be taken with a rather large grain of salt. Going by your 100% beat rate, I'm betting you never hit the dragstrip.
Lith wrote:On another note I measured up my 25det neo engine last night and if I cut the fire wall and made custom front mounts it would fit if I sat it 100mm back in the car :p
Honestly think what you are currently planning is cooler.
Shrike wrote:Tbh its not that hard to go to a test day at manifeild or go to a burnout comp in levin so I dont feel the need to do shit on the road
Shrike wrote:dnalunchie wrote:Shrike wrote:jacobrjett wrote:Personally I admit to myself that while its easy to compare our levins to integras... we should know the Type R is a lot faster...![]()
Was the car in my build log when I first got it so ae111
Trd s/s with dampner adjustment
Trd strut bars
twinpots with good pads
Cai
Kaimoto exhaust with apexi muffler and cat deleted
Stage one port and polished blacktop head
280 degree cams
Toms ecu with a/f mixer and a retune (no speed cut)
Trd headgasket with a shaved block
No aircon
Lsd C56
Trd 3.8kg flywheel
Trd clutch
Running on 98
No sound deadening
No boot trim
Toms kit (lighter then factory I have weighed it)
Battery in the boot for better weight distrabution
5zigen rims with 215 tyres
I suspect other things were done as well but this is all I have found/am aware of and tbh I drive like a manic haha
