Why you dont drive your racecar to the track... with VIDEO!!
Postby flygt4 » Sat Aug 05, 2006 10:07 pm
isnt there whole race series using that engine? surely someone must be involved with that somehow? toyspeed is full of motorracing whores :D
i have heard from a lot of people that they are a very peaky engine, they are still only about 5 years old though , so they havent really trickled down into a price range where people are gonna start getting serious with them.
flygt4
Postby KinLoud » Sat Aug 05, 2006 10:31 pm
Go out and drive a 2zzge car. Fantastic! It pulls very hard and then the VVTL thing happens and you go even faster!
Stu (Taupo toyspeed occasional poster) let me drive his Will 2 years ago. Awesome!
I understand that they don't tolerate overrevving on the downshift. Maybe some other probs also. I think most probs were on the early 2zzges.
Ken
Ham
021 408863
Postby Leon » Sat Aug 05, 2006 10:37 pm
In reply to Jeremy, yeah, but they're all built up by Lynn Rogers, at a cost of a zillion dollars each, and are dry sumped and stuff. So you're probably going to be dropping somewhere in the region of $20k to get a similar set up, and have to wait 18 months to get it ;)
Postby matt dunn » Sat Aug 05, 2006 11:16 pm
hmmm.
The class I race in is 0 to 1800cc. looking at a 7AGTE,
but how about,
2ZZGTE??
Main problem I forsee is budget.
Matt
Postby Mr Revhead » Sat Aug 05, 2006 11:21 pm
not that much leon!!
they are stock engines. just the out side bits are changed.
i have heard of a few failures of the oil pumps. however i only know of 2 first hand and one was a pulley damaged in an accident and not picked up on repair and the other was supposedly an aftermarket pulley.....
so yes there has been issues, but its not an endemic problem imo
Postby Dell'Orto » Sat Aug 05, 2006 11:26 pm
Mr Revhead wrote:not that much leon!!
I was reading some Celica forum from the US, and they also reckoned that underdrive pulleys tend to cause them to shear the oil pump drives. Was a few there that had it happen to them.
Postby RedMist » Sun Aug 06, 2006 12:35 am
matt dunn wrote:hmmm.
but how about,
2ZZGTE??
Matt
I'll have to come down there and have a play. My Lancer fits the bill nicely.... just need to fit some road tyres and stiffener her a bit.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby mtrntr » Sun Aug 06, 2006 10:10 am
Bugger Ken,
So does this mean I should put the Tezza engine back on the market?
mtrntr
Cruise Mastah
Postby Leon » Sun Aug 06, 2006 11:48 am
Remember that anything turbo you multiply your cc rating by 1.7. So you're going to be out of the 1800cc class if you're over about 1050cc with a turbo. 4AGTE = 2720cc as far as engine rating goes.
Postby Leon » Sun Aug 06, 2006 11:49 am
Would you care to make a small wager on that ;)
Postby Dunny » Sun Aug 06, 2006 11:50 am
but how about,
2ZZGTE??
Matt
1587cc x 1.7 = 2698cc so would you not be 2500cc-3000cc class :?
As for the lancer not sure of exact cc but suspect would also be in the over 2500cc class
Dunny
Postby Mr Revhead » Sun Aug 06, 2006 11:56 am
Would you care to make a small wager on that Wink
i bet you $10k i can get one for $10k 8)
matts talking about sports saloons, 0-1800cc turbo :P
Postby RedMist » Sun Aug 06, 2006 12:40 pm
but how about,
2ZZGTE??
Matt
Matt's talking about the 7agte IE a 7afe with a 4age head and a turbo strapped to it. Its natively 1762cc so it gives a corrected cc of 2995.4 IE just under the 3ltr limit. The Lancer unfortunately is 1834cc so wont compete in the same class.
RedMist
Postby matt dunn » Sun Aug 06, 2006 7:14 pm
Well if you wan to get technical, here are the specs.
I run class T2.
Class C 0 - 1850cc naturally aspirated
Class B 1851 – 3000cc naturally aspirated
Class A 3001 – 6000cc naturally aspirated
Class T2 0 - 1850cc forced induction
Class T1 1851 – 3000cc forced induction
And Weights
4.4 Minimum racing weight for all cars with forced induction engines for the following swept volume categories is:
Class T2 0 to 1850cc 980kg
Class T1 1851 to 2000cc 1050kg
2001 to 2500cc 1280kg
2501 to 3000cc 1350kg
Matt
Postby RedMist » Sun Aug 06, 2006 8:24 pm
I stand corrected.
The Lancer is in the same class. Although a couple of hundred kilos too heavy.
RedMist
Postby Dunny » Sun Aug 06, 2006 11:04 pm
matt dunn wrote:Well if you wan to get technical, here are the specs.
I run class T2.
And Weights
Matt
Sports saloon regs are diff to any others (ie club regs), I guess their class specifications are just explained differently
Dunny
Postby fangsport » Mon Aug 07, 2006 4:50 pm
RedMist wrote:I stand corrected.
no, the Lancer is within the regs. they are minimum weights. so the trick is to take 300kg out, then fit balancing ballast up to the weight limit.
fangsport
Postby RedMist » Mon Aug 07, 2006 9:05 pm
http://www.cars-directory.net/specs/mit ... _10/19347/
1120kg stock. I haven't weighed it yet, but with the full cage in it I doubt it will be light. I certainly wouldnt expect it to be under the T2 limit. It is a big 4WD car after all.
RedMist
Postby Punter » Mon Aug 21, 2006 12:06 pm
Hey ken,
You decided what your going to do with the carina yet?
I saw this on trade me and thought you may be interested.
Rob.
Punter
Postby barryogen » Mon Aug 21, 2006 5:22 pm
Adamal wrote:Ok, sorry about that. :)
Does anyone have any experience with their reliability?
I have one.
Lotsa fun.
Not torqueless in the lower revs as some say. They have a definite kick at 6000RPM as it engages the other cam.
They have been semi known for blowing oil pumps apart, usually caused by a mis-shift of somesort, mine suffered from an exploding/disintergrating oil pump, Lotus sorted it by changing how the H pattern for gear changes was, apparently putting a mild slant on it.
They have been semi known to bend valves/valve float if you play in the higher revs too much, but thats sorted with some stronger valve springs.
This is by no means a be all and end all post on the 2zz... but it could be helpfull.
Staying NA...
TRD make a kit for it with higher compression pistons and some other goodies.
http://trdparts.jp/english/parts_2zz-engine.html
13:1
Monkey Wrench Racing have a few kits and have after market cams for it... they also have a stroker kit for it to take it to almost 2L.
Supercharger wise, Blitz kit is ~$8k NZ, and two weeks to send factory ECU to somewhere to be re-written, apparently runs lean in the upper revs. 225WHP
Greddy SC kit is ~$5k, no intercooler, and about the same performance as the Blitz kit... also known to run lean in higher RPM. 230WHP
Turbo kits
Monkey Wrench Racing, Hass Auto, and C2power all have kits, all put out about 250WHP
There is a few exceptions to this... there is one or two known to be ~380WHP, and the highest one I have seen online is 420WHP, but nothing has been offered as hard proof for these.
I know that this isn't the intended use, but in standard form, the 180HP(crank) is a lot of fun in a FWD, now that I have got a bigger stronger sway bar, a lot of the single spinning has gone, replaced with traction that I didn't think it was capable of... LSD on the way for future upgrades.
Incidentally, there is a lot of info of people putting them in the little gay MRS or MR2 Spyder as known in the US... and with an LSD, they're meant to be a lot of fun.
thus ends probably the longest post I have made.
lots more info here.
http://dave.net.nz/old_site/
barryogen
2ZZ Guru in training
Users browsing this forum: Bing [Bot] and 8 guests
