andyling wrote:BZG|Bling wrote:That you can drive your car on?Most likely no.
oh, fxxk that, so how do you guys know your rides top speed?
touge_ae101 wrote:andyling wrote:BZG|Bling wrote:That you can drive your car on?Most likely no.
what does a top speed tell you anyway? its just comes down to gearing and your aerodynamic vs power ratio as to how much your engine can push the shape of the car through the air.
there are plenty of straight bits of road that in NZ which you COULD max your car out on but apart from a bit of a rush it doesn't tell you jack sh!t.
plus most cars are limited to 190kph if std ecu anyways.
andyling wrote:touge_ae101 wrote:andyling wrote:BZG|Bling wrote:That you can drive your car on?Most likely no.
Sorry, not starting a argument here.
I'm talking about a built drag car bro, Please don't max your ride at motorway or any other roads apart from the strips/racetrack.
Thay did not put mine on there but i did run two 10s runsgt4dude wrote:i dont see many quick toyotas in the results list
just a couple 12sec supras and a caldina
