IH8TEC wrote:pfft, why port a small port when you can start with big ports already
1I1 wrote:what about the KE70 in the current NZPC mag, 331kw at rear wheels? (not sure if that figure is with nitrous or not tho)
l1ttle_d3vil wrote:1I1 wrote:what about the KE70 in the current NZPC mag, 331kw at rear wheels? (not sure if that figure is with nitrous or not tho)
that was @ 26psi without the nos
touge rolla wrote:I think he means as N2O is a power adder in the same way a turbo is. Rather than a "pure" NA engine.
4agtepwr wrote:Mines stock internals, No fancy rods and just toyota ze pistons, Be really keen to see a dyno plot and learn a little more about the engine for sure, be keen to see a plot of the boost curve as well because mines fairly laggy with GT3071r and that had supposedly a GT3582r which is a fair bit bigger. Very well done though. Will have to lean on mine a bit harder now, If I could get a decent intercooler in there it would bring it up bit, then theres always C16
