top gears fav sporty toyotas
Postby STR » Mon Oct 24, 2011 11:32 am
I always thought MR-2 referred to it being Mid engine, RWD and a 2 seater?
82 KP60 4AGTE race car
S.T.R - Shopping Trolley Racing!!!
STR
Postby iOnic » Mon Oct 24, 2011 11:51 am
MR2 doesn't "officially" stand for anything. But Toyota did advertise them using the phrase "Midship Runabout" and the 2 is assumed to refer to the seating configuration.
Postby deaf_rattle » Tue Oct 25, 2011 11:25 am
http://www.topgear.com/uk/photos/foreig ... ?imageNo=7
Foreign cars we wish we'd got
Toyota Century
The only front-engined, rear-wheel-drive, V12 car Japan produces, the Century is a mighty lump of modern-retro-expensive brilliance. Looking like a monster Nissan Cedric, Toyota's home-market flagship gets a 276bhp, 5.0-litre V12 and has been produced in Japan since 1967, with its only major redesign in '97. The doors are fully electric, the suspension courtesy of air-ride, most are ordered with wool trim (quieter than leather) and have lace curtains in the rear instead of tints. Timewarptastic. Cost? Just £61,000. In Japan, at least.
Postby BZG Wagon » Tue Oct 25, 2011 12:11 pm
new_breed wrote:http://www.topgear.com/uk/photos/foreign-cars-2011-10-24?imageNo=7
Toyota Century
Crap that's awesome!
The 1GZ-FE is a 5.0 L (4996 cc) V12 48-valve DOHC engine with variable valve timing (VVT-i). Bore is 81 mm and stroke is 80.8 mm, with a compression ratio of 10.5:1. Official output as per Japanese Manufacturers' Agreement is 206 kW (276 hp) at 5200 rpm although true power output is estimated to be around 230 kW (310 hp). Peak torque of 481 N·m (355 ft·lbf) is at 4000 rpm with over 400 N·m (300 ft·lbf) available from as little as 1200 rpm. The fuel injection system is controlled by two ECUs, one for each bank of cylinders. The engine is capable of running on a single bank of 6 cylinders should a malfunction occur.
BZG Wagon
Postby wde_bdy » Tue Oct 25, 2011 12:15 pm
There are a few of those engines floating around NZ going into various cars. I know of one early model Crown and also a Celica running twin turbo.
Callum
wde_bdy
Postby ~SlideWays~ » Tue Oct 25, 2011 1:06 pm
wde_bdy wrote:There are a few of those engines floating around NZ going into various cars. I know of one early model Crown and also a Celica running twin turbo.
Callum
Have seen one in the flesh, HUGE engines... fugly though.
~SlideWays~
Postby GTTpower » Tue Oct 25, 2011 1:51 pm
Pretty sure 'fuel' used to have a century.
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Previous: 1993 EP85 Starlet, 1984 KP60 Starlet
Steam/Origin ID: nzEP85
GTTpower
Postby Mr Revhead » Tue Oct 25, 2011 1:55 pm
Callum
picsorban
Postby Snoozin » Tue Oct 25, 2011 1:58 pm
GTTpower wrote:Pretty sure 'fuel' used to have a century.
He did, it was a V8 one though.
There's a handful of Century's kicking about in NZ. Albany Toyota has a LWB/limo version sitting there in the showroom.
Snoozin
Postby wde_bdy » Tue Oct 25, 2011 2:17 pm
Callum
picsorban
On Toymods (the Crown might be on Oldschool too?), not willing to post pics of other peoples cars for them.
Callum
wde_bdy
Postby wde_bdy » Tue Oct 25, 2011 2:20 pm
Although here is a Century motor (only V8 though) in a Corolla.
Callum
wde_bdy
Postby cogent » Tue Oct 25, 2011 3:36 pm
I thought someone on here got a chance to work on the century engine and basically concluded the 1uz was a much more impressive engine?
cogent
Postby wde_bdy » Tue Oct 25, 2011 3:43 pm
Depends what it was built for, it does a superb job of effortless, smoothly and quitely lugging around a whale of a car with some quite impressive acceleration if required. Scope for performance enhancements is a little limited and expensive (12 rods, 12 pistons, 48 valves etc), rods are similar to late 1UZ so won't take a lot of abuse. It also has 3 computers to run it so would give any auto electrician nightmares.
Callum
wde_bdy
Postby Timmo » Thu Oct 27, 2011 11:18 am
The problem when talking about the Soarer is there were 4 major variants each with slightly different aims. That said, they were definitely Grand Tourers (GT) designed to travel long distances, at speed, in comfort rather than being track weapons- The steering was too vague, the brakes too weak and the car too nose heavy (and too heavy overall) for a proper sports car. The basic structure was there of course, but Toyota already had a six cylinder super sports car in the Supra, and a couple of 4-cylinder cars too...so they didn't need another car in that segment of the market.
The most 'sporty' was the Jzz30 (the most powerful, the lightest and only one with an option of a manual transmission), the least being the Uzz30 (steel springs) or Uzz31 (Air suspension) with the Uzz32 (Active suspension) somewhere in the middle.
It's a bit like Nissan with the Skyline 350 GT and the 350Z: Similar cars but slightly different aims.
Sporty- Yes, Sports cars, nope.
Lightweight baby
1991 MX5 Supercharged
Timmo
Postby mr_monkey » Thu Oct 27, 2011 11:51 am
ok ok, i stand corrected.
Supra is not a sports car I've decided. Its a supercar :-)
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby deaf_rattle » Thu Oct 27, 2011 11:54 am
mr_monkey wrote:ok ok, i stand corrected.
if the supra is a super car, you need to include the 3000gt (gto), nissan 300zx, nissan skyline gtr, mazda rx7 in your list of super cars.
But none of them are supercars. I think the only japanese car that came close (before lfa) was the honda nsx
Postby Mr Revhead » Thu Oct 27, 2011 12:34 pm
Nah the NSX was a sports car :P
Postby deaf_rattle » Thu Oct 27, 2011 12:56 pm
Mr Revhead wrote:Nah the NSX was a sports car :P
lol, i was going to call it sporty, cause of the nice little spoiler on them
Postby rollaholic » Thu Oct 27, 2011 5:29 pm
theres some great vids on youtube of the nsx smashing all kinds of exotic cars on race tracks
Postby iOnic » Thu Oct 27, 2011 5:55 pm
There are videos on Youtube of Honda Civics smashing exotics on the track...
Users browsing this forum: Bing [Bot] and 21 guests
