RunningRich wrote:dnalunchie wrote:or you know, buy a DC2 and not have to worry about anything lol
Apart from your lack of self respect...
erm? srs?
A great car that looks good and goes awesome.... man how embarrassing
FST4RD wrote:dnalunchie wrote:or you know, buy a DC2 and not have to worry about anything lol
Brakes? What are the factory ones like? 4 stud or 5 stud ones?
Only thing with non turbos are you spend twice as much to go half as fast as a turbo... Although reliability and less to go wrong.
dnalunchie wrote:FST4RD wrote:dnalunchie wrote:or you know, buy a DC2 and not have to worry about anything lol
I have owned a type R integra at the same time a mate owned a v8 wrx
We took it out in the middle of nowhere and did a few make shift 1/4 mile drags
We were exactly even.
The type R integra makes between 130-140kw atw completely stock and weighs 1080kg
A mid 90's wrx or evo makes around 160kw atw and weighs just below 1300kg
Therefore if you assume 140kw for the DC2 and 160kw for the turbo
we come up with a power to weight rate of 5.7kg per hp for the tyre R and 6.0 kg per hp for the turbo.
dnalunchie wrote:[
FST4RD wrote:i like the 98 model itr's the 5 stud ones with the factory wheels (still a dc2?). I would have one in a heartbeat. But i assume they only have dodgy old 2 pot front brakes? Whether the brembos from the later model fit?
Only thing with turbo though is it's easier and cheaper to make them go faster if that's your thing.
strx7 wrote:dnalunchie wrote:[
They make 149KW (200hp) at the flywheel bog standard.........
140kw at the wheel is NOT std in any way shape or form......
they might make close to 130kw on a hub dyno, that that isn't at the wheels, that is at the hubs, which is a different thing again........
strx7 wrote:around a track they can be fast, driver abilites and car set up have a lot to do with it.
Leon wrote:also worth noting, in *most* competition events where the class is defined by engine size, an 1800cc non turbo car puts you in a way easier class to get a good result in without having a big budget car.
Because if you're in the 2000cc and over class with a turbo car (for MSNZ events in a turbo car you multiply the cc rating by 1.7, so 2000cc turbo = 3400cc for class purposes) you're in with a group of people more inclined to spend some *serious* coin on their cars.
That's my experience in 18 years of club level competition anyway. There will be exceptions to the rule, as I'm commenting only from my own experience.
strx7 wrote:Leon wrote:also worth noting, in *most* competition events where the class is defined by engine size, an 1800cc non turbo car puts you in a way easier class to get a good result in without having a big budget car.
hit the nail on the head. if you want to play with a 4wd, you basically need to build a car with and have the driving abilities to win an event outright, as being 1/2/3 in the 4wd class usually means being 1/2/3 overall.
Historically, the 3 under 2000cc catergories have been realatively cheap to be competitive in, however in the past 3-4 years with the shift in rallying away from the 4wd turbo vehicles, more people are building fairly serious 1601-2000cc 2wd cars, and that class is now almost as competitive as the 4wd class. playing in the 1600 class with either a 4AGE or B16A is still the easiest and cheapest way to place in class.
TRD Man wrote:was told of an EVO3 rally car the other day for $7K. Got to be cheap motorsport.
