Postby iOnic » Thu Apr 03, 2014 7:04 pm
Reduced cleanliness
Postby GDII » Thu Apr 03, 2014 7:05 pm
Wasn't today but last week and not my car. Helped a mate change his stuffed TRD struts in his AE101 BZT. That all went fine and very quick.
After asking what fuel he uses he said 91. I'm pretty sure blacktop engines are meant to run on 95 because the ECU is tuned for it and the compression ratio is way above 10:1. Is it 11:1? Will running on 95 get better fuel economy? Pretty sure it will.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Mr Revhead » Thu Apr 03, 2014 7:14 pm
95 minimum. 98 preferred. It'll be running like shit on 91
Postby GDII » Thu Apr 03, 2014 7:21 pm
Maybe that's why he cracked the head on the other engine.
1990 SW20 MR2
GDII
Postby Kiwi-Corolla » Thu Apr 03, 2014 7:29 pm
Yeah it'll run like shit on 91, probably pings like crazy too. Wouldn't be the only one doing it though. Lost count of how many times I've seen people with 4A-GE's and 2ZZ's etc filling up with 91 at the gas station :roll:
Kiwi-Corolla
Postby GDII » Thu Apr 03, 2014 7:35 pm
I did advise him that it would be pinging and dumping fuel to compensate. Will tell him to use 95 to keep it running better. I've just gone from running 91 to 95 in the EP81 to stop pinging. Runs good now.
1990 SW20 MR2
GDII
Postby Mr Ree » Thu Apr 03, 2014 8:52 pm
Refitted turbo compressor cover, oil feed and drain lines, intercooler piping and couplers, intake pipe and filter, and started it up to check for leaks, of which there were none.
Took it outside the garage and let the exhaust heat wrap emit its toxic stench, then took it for a road test.
Roll on Manfeild next weekend :)
wak thud gush!
Mr Ree
Postby Dell'Orto » Thu Apr 03, 2014 9:15 pm
Partially got rid of the commodore! Now have 6 cars and a motorbike :lol:
Postby DRFTIN » Thu Apr 03, 2014 11:23 pm
removed front strut from racecar to replace top hat
realised bearing i thought was worn was actually just a loose nut
half reinstalled it gave up and went home
DRFTIN
Postby Lloyd » Fri Apr 04, 2014 10:06 am
Kiwi-Corolla wrote:Lost count of how many times I've seen people with 4A-GE's and 2ZZ's etc filling up with 91 at the gas station :roll:
That's because you spend so much time there ;)
Postby Mr Ree » Fri Apr 04, 2014 11:37 am
Haha ^
wak thud gush!
Mr Ree
Postby Alex B » Fri Apr 04, 2014 2:14 pm
Oh snap
Postby Dell'Orto » Fri Apr 04, 2014 3:26 pm
Oh my lols :lol:
Commodore is gone, Mondog has replaced it. Realising I've spent $40 on change of ownerships in a week makes me laugh an awful lot.
Also spent the morning at PAP stealing manual conversion bits for the black Primera
Postby thegreatestben » Fri Apr 04, 2014 3:34 pm
Pap needs some shaded areas. It's like a mini desert up there.
thegreatestben
Postby Leon » Fri Apr 04, 2014 4:05 pm
Dell'Orto wrote:Commodore is gone, Mondog has replaced it.
Have you got a Mondeo you sick bastard?
Good lord man.
Postby Dell'Orto » Fri Apr 04, 2014 6:17 pm
Yep will be cleaned up, WOF'd and put on TM asap. Is an 02 so A. worth heaps more than the commy and B. easier to sell
thegreatestben wrote:Pap needs some shaded areas. It's like a mini desert up there.
$&#$% yes, I nearly died up there today. A drinking fountain wouldn't go amiss!
Postby 85AW20v » Fri Apr 04, 2014 9:59 pm
Kiwi-Corolla wrote:Yeah it'll run like shit on 91, probably pings like crazy too. Wouldn't be the only one doing it though. Lost count of how many times I've seen people with 4A-GE's and 2ZZ's etc filling up with 91 at the gas station :roll:
You only see that many people because you're in the petrol station all the time putting $20 in :lol:
See ya
Simon
85 MR2 20v
85AW20v
Postby Leon » Fri Apr 04, 2014 10:24 pm
Dell'Orto wrote:Yep will be cleaned up, WOF'd and put on TM asap. Is an 02 so A. worth heaps more than the commy and B. easier to sell
Mondeo will be about as easy to self as raging herpes ;)
Postby loudstealthGT-Four » Fri Apr 04, 2014 11:13 pm
Your about half a day late with that burn :lol:
loudstealthGT-Four
