Dwyer Magnehelic Guage - Bulk order possibility
Postby Stealer Of Souls » Wed Nov 16, 2005 9:04 am
Hi all.
I don't know how many people would be interested, but I'm looking at the possibility of purchasing Dwyer Magnehelic Differential Pressure Guages direct fro Dwyer Instrumets (www.dwyer-inst.com).
With the current exchange rates it's cheaper to buy them from the US providing I can get at least 3 or more...
These are the two main products I'm looking at...
http://www.dwyer-inst.com/htdocs/pressu ... 0Price.cfm
But would order anything they make if wanted...
Basically the Magnehelic is an incredibly sensitive guage for measuring pressure. The magnehelic has been used a bit by the Autospeed authors to determine all sorts of things...
High pressure points for siting cold air intakes, vents etc
Intake restrictions,
Measuring pressure differentials across heat exchangers.
Here's a few articles where they've used them in testing (or a simliar device).
http://autospeed.drive.com.au/cms/A_2159/article.html
http://autospeed.drive.com.au/cms/A_0629/article.html
http://autospeed.drive.com.au/cms/A_1023/article.html
http://autospeed.drive.com.au/cms/A_2518/article.html
http://autospeed.drive.com.au/cms/A_0987/article.html (This is actually about using a pressure switch to determine if the filter is particularly dirty and requires cleaning... But you could set up a guage to measure the actual "dirtiness".)
I guess the Magnehelic is really an R&D type tool. But I figure there may be some interest in them.
If anyone is interested in getting one then leave a post here.
I'd probably need at least one other buyer as I'm looking at getting two guages. And there is no rush. I won't be ordering till the new year as I'm going away soon and won't be back till after xmas.
'86 AE85.5 Levin
Stealer Of Souls
Postby Stealer Of Souls » Thu Nov 17, 2005 2:33 pm
bump?
'86 AE85.5 Levin
Stealer Of Souls
Postby RomanV » Thu Nov 17, 2005 5:25 pm
So, this is just a gauge that would be used in conjunction with a manometer?
Postby Stealer Of Souls » Fri Nov 18, 2005 8:30 am
It's a replacement for a manometer.
Better in that they are self contained and are like any other guage. You can hold them on any angle, you just plug in a pipe (or two) and off ya go...
In other words....
They are a VERY VERY sensitve pressure (boost/vacuum) gauge. The most sensitive ones can read 0-.018 PSI, while the most high pressure one reads 0-30psi...
'86 AE85.5 Levin
Stealer Of Souls
Postby RomanV » Fri Nov 18, 2005 10:57 am
Oh really!
Hmmm, sounds interesting....
I might be keen!
