supraman_nz wrote:The Veyron is limited to 406km because of tires
Maybe I'll just by a Callaway V16 and fit it to the MR2 instead
supraman_nz wrote:im sure you could fit that in for less than a veyron. . . might need to mod it a tiny bit to fit though
supraman_nz wrote:oh that picture makes it look huge as.
But still at the end , you wouldnt be as fast as a veyron.
Adamal wrote:Capacity??
fivebob wrote:What an excellent use for four Yamaha FZR 1000 engines
Brick wrote:does that sme 80valve on the side of it? its not very clear![]()
but pass on buying aftermarket cams for that
fivebob wrote:Adamal wrote:Capacity??fivebob wrote:What an excellent use for four Yamaha FZR 1000 engines
Hmm lets see that'd be 4x1000cc, too hard for me to work out![]()
Actually I think you can bore them to about 1250cc each, so maybe 5 litres is possible.
