Serious knock....
Serious knock....
Postby Chickenman » Tue Dec 06, 2005 1:13 pm
Has anyone got some pictures of knock damage in a 3sge or blacktop 20v?
Baby Jesus
Chickenman
I Am The Walrus!
Postby RomanV » Tue Dec 06, 2005 1:41 pm
Knock Knock...
Who's there?
Late model 3sge. :lol:
Heres a high res closeup.
http://img227.imageshack.us/img227/5333 ... on31vp.jpg
Postby Malcolm » Tue Dec 06, 2005 1:52 pm
holy f*cking shit!
I've never seen knock damage like that! jebus!
is that from your new motor? what was the head like?
Postby Chickenman » Tue Dec 06, 2005 1:54 pm
That is $&#$% impressive 8O :o :lol:
Precisely what I was looking for dude, thankyou.
Baby Jesus
Chickenman
I Am The Walrus!
Postby RomanV » Tue Dec 06, 2005 2:05 pm
All_Fours wrote:holy f*cking sh*t!
Not a bad effort for an NA. :lol:
Notice the large chunk of the ringland that is missing in the foreground.
Im not sure what exactly someone was doing to this engine, I would imagine it was courtesy of some very high RPM leaning out.
It sure is. My new pistons look a lot nicer however. :)
Definitely not as bad as the piston!
There is still some pitting on the surface of the head, but I had Lynn completely strip the head down, check everything for damage, machine the face of the head, etc. etc.
So its fine now. 8)
The head still looks a bit damaged in that cylinder, but I have Lynns assurance that it is only aesthetic, and very minor. He said that they could weld in some metal and grind it flush if I insisted, but there would be no point.
I dont have any pics of the head at the moment, but can take some when I get home if you are interested.
Postby Adamal » Tue Dec 06, 2005 2:38 pm
Looks like there was a pachinko machine in your engine :D
Postby Low_Aa63 » Tue Dec 06, 2005 6:49 pm
what timing where u running?
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby Low_Aa63 » Tue Dec 06, 2005 6:50 pm
woops that wasnt to clear...i meant what degree was it at?
The list so far
Low_Aa63
Postby RomanV » Tue Dec 06, 2005 6:56 pm
Impossible to say.
I wasnt the one that blew it up. :)
However I can tell you that it was running the standard ECU, with an HKS fuel computer spliced in.
Postby Kitrix » Tue Dec 06, 2005 10:03 pm
this is half of the big end bearing out of my blacktop. apparently its ment to be twice as thick, not curved at the edges and youre ment to be able to see yourself in it. excuse pics had to take em with my phone. camera has gone walkies :roll:
http://toyspeed.blakjak.net/profiles/profile.php?id=1846
Kitty. 7 cars in 3 years... got commitment problems?
Kitrix
Postby vvega » Fri Dec 09, 2005 9:05 pm
lol @ spun bearing
v
vvega
Postby turbo86 » Fri Dec 09, 2005 9:33 pm
are you sure it wasnt turboed, hence the high compression with alot of boost? thats what it looks like otherwise i dont see how an NA could $&#$% those pistons that badly. ive crack pistons on factory turbo engines and only the ring lands usualy go but they dont look as bad as those.
3sgte ae86
turbo86
Postby CozmoNz » Fri Dec 09, 2005 9:46 pm
im sure if you sat her at 8000odd rpm, then quickly used a fuel comp (as it was equiped with) to turn the af up (leaner), youd manage some serious damage....
Rayne For President!
CozmoNz
