Wheel spacers and certs.....
Postby Levin » Fri Dec 30, 2005 9:02 pm
Hey I'm after information regarding wheel spacers. Basically I want to know if you need a cert for them or not. Any help would be much appreciated.
Levin
Postby BBBrad » Fri Dec 30, 2005 10:14 pm
Has to be of the "bolt" on type. None of those little 5mm spacers that get sandwiched between the hub and wheel.
This info came from a certifier. But I would imagine there would be some that dont even like the bolt on type?
My new car...99 mr-s
BBBrad
Postby vhpacer » Fri Dec 30, 2005 10:25 pm
You dont need a cert if you put on the original wheels for a wof 8)
Na but the cops never notice them, I got a warrant with some bolt on ones on my sr, but that was at a country garage so I dont no what it would be like at a testing station
vhpacer
Postby wde_bdy » Fri Dec 30, 2005 10:27 pm
Has to be certed, and there are limits on the size you can have them.
Callum
wde_bdy
Postby soopachargen » Sat Dec 31, 2005 9:34 am
You dont need a cert if you put on the original wheels for a wof Cool
no thats not dodgy.... sure it got you your warrent but when the insurance company look at it after its been written off... bye bye to your insurance
When in doubt, down and out.
soopachargen
Postby KE20 » Sat Dec 31, 2005 11:19 am
i got 25mm spacer/adaptors on the front and 45mm on rear, got cert, they didnt notice, got wof for testing station on sunnybrae rd and didnt notice, and my wheels stick out 2" allround
Garage Dori
KE20
Postby no_8wire » Sat Dec 31, 2005 12:07 pm
Dont you fail a warent if you tyres stick out past your guards?
no_8wire
Postby CozmoNz » Sat Dec 31, 2005 12:16 pm
you should fail if your track is increased by a maximum of 25mm either side.
Rayne For President!
CozmoNz
Postby rxtoy » Sat Dec 31, 2005 1:03 pm
in the lvvta section of performance car they covered this a few months ago (quite a few i think). all spacers need a cert to be legal, they can be certed up to 10mm for slide on ones and up to 25mm for bolt on one's, anything over can't be certed.
heaps of people seem to get away with it, i'm going to get mine certed but the car needs a cert anyway so it would be stupid to not do them.
as for the increase in track width most people run spacers so they can swap to different offset rims which would mean minimal change in track width.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby Levin » Sat Dec 31, 2005 6:50 pm
probably just easier to not bother with wheels that require spacers then i guess
Levin
Postby KE20 » Sat Dec 31, 2005 6:52 pm
ive gone from 15x5" to 17x9.5" and 17x10". its on my ute, but i also get away with no centre bake light as well, maybe coz it a 'commercial vehicle', not a 'performance vehicle'.
Garage Dori
KE20
