Where to get...
Where to get...
Postby fuel » Tue Jan 24, 2006 6:04 pm
Where would I get some aftermarket sway bars for my TE71 Corolla? As far as I know, they are the same as the AE85/AE86. Mine has mega body roll from 'nam, and I hope to sort it out with a stiffer/bigger sway bar and some stiffer suspension.
LOUD NOISES!!!
fuel
Postby z|gen » Tue Jan 24, 2006 6:40 pm
try whiteline..they generally have alot of aftermarket parts for the older generation toyotas.
or if its exactly the same as ae8* parts, then just find ae8* parts.
most japanese tuners and suspension places will have some form suspension parts to suit.
AE91 SUPERCHARGED COROLLA
z|gen
Postby Jebus » Tue Jan 24, 2006 6:44 pm
New shocks + springs will fix it.
Jebus
Postby GT4 20 » Tue Jan 24, 2006 9:16 pm
No one seems to make uprated front sway bars for the ST205 so I went to Snells in AKL with an OE bar and said "Copy this using 19mm bar" and they did. :D
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby KinLoud » Tue Jan 24, 2006 9:28 pm
redo all the bushes that hold the swaybar and the bushes for the links.
This will mean that the swaybar will start to work as soon as you start to turn ... not when all the slop in the bushes have been taken up.
Ken
Ham
021 408 863
Postby fuel » Tue Jan 24, 2006 9:42 pm
^^ Good point Ken. I didn't think of that. I plan on replacing the struts/shocks and springs at some stage, but wanted to complete the setup with a better sway bar.
LOUD NOISES!!!
fuel
Postby deaf_rattle » Wed Jan 25, 2006 6:39 am
sway bar would be the last thing i would do.
do the shocks and springs first as suggested, you will probably find that it handles alot better then.
And if thats till not good enough, nolathane bushes.
and that money that you thought you had to spend on an uprated swaybar can be spent on something else
