Spray painting : Who here has used ....
Postby GTCRSHR » Wed Feb 08, 2006 3:21 pm
House of Kolour Paints ?
i wanna pick your brains
Nothing to see here ...
GTCRSHR
Postby Wildcard » Wed Feb 08, 2006 7:34 pm
Voted worlds most badly chosen and uninformative title 2006.
Wildcard
Toyspeed Founder
Postby Malcolm » Wed Feb 08, 2006 8:39 pm
haven't used them, but done quite a bit of enquiring in the past to people that have. What are you wanting to find out anyway?
Postby BlakJak » Wed Feb 08, 2006 9:17 pm
Wildcard wrote:Voted worlds most badly chosen and uninformative title 2006.
Agreed. He knows now... thats two ive seen in 2 minutes :| and thats 2 too many... folks keep your subject lines useful!!!
BlakJak
Postby GTCRSHR » Wed Feb 08, 2006 9:41 pm
sorry hopefully thats a little better,
all_fours
i want to know how easy the "kandy" side of things is to work with and if theres any pit falls or anything i should know in regards to working with them ?
GTCRSHR
Postby Malcolm » Wed Feb 08, 2006 10:50 pm
well, that happens to be exactly what I was finding out about.
Where are you located in Aucks? I used to talk to the guys at LJ Smits in East Tamaki, they are HOK's importers. Anyway the main advice I got was to make sure you give an equal number of coats to everything, be careful not to overlap too much in the same spot or you'll get uneven colouring over the car. Also you really want to use a reasonably light basecoat, like white or silver, as black and other dark colours give you quite a dull candy effect. Also the HOK website has some pretty good info on application techniques etc
Postby GTCRSHR » Thu Feb 09, 2006 10:06 am
yep thats where i have been (have alwasys gone there for great advice great products and least of all great prices!)
was talking to a maori guy( black guy not to sure on nationality) but he gave me some good ideeas, at this stage i had no idea on how the candy effect was acchieved or anything
but what im going to go for is :
Primer
White base coat
Colour
KANDY
then about 8 coats of laquer sanding down with 2000grit in between coat 3 and 5
and then cut and polish after about a week,
is this correct to your understanding ?
GTCRSHR
Postby Malcolm » Thu Feb 09, 2006 10:18 am
the kandy effect is basically achieved by many layers of semi-transparent paint (that's the kandy). What basically happens (afaik) is that depending on the angle that the sunlight passes through and reflects on, you either see more of the basecoat or more of the kandy coat.
What colour are you intending on using as the base? There's probably no point in doing the white basecoat before another colour coat, infact you can even use the primer as the basecoat if it's the desired colour, and just kandy over that.
Also 8 coats of clear might be excessive 8O And I don't know if you meant 2000 grit (rather than 200!), but that might be excessively fine also, 1200 would be plenty and it wont take you so long to sand it!
Postby GTCRSHR » Thu Feb 09, 2006 10:29 am
so the candy is just mixed up the same as the ordinary colour and then applied over the colour that the car should be ..correct :?:
im not to sure on what colour i will do it yet... i actually like the standard black colour :oops:
and yeah i did mean 2000 grit ! i prefer to work with the 1600/2000grit to be honest in the past it has ment a finer finish it might take a bit longer but the end result is a better finish i have found
same with the 8 coats, it will probably end up being 6 coats after the sanding to give that super glossy look :) and the final polish will finish it off nicely
some of the hot rods have in excess of 10 coats 8O
if i go ahead with this i will send you through some pictures when its done,
GTCRSHR
Postby Malcolm » Thu Feb 09, 2006 10:38 am
afaik the kandy is mixed/applied very much the same as a clear coat, just taking extra care with getting it on evenly. You can do kandies over black base but all the little swatches LJ Smits had of them looked very dull, you can get quite a dark/blackish colour by doing many coats of kandy over a lighter basecoat, which I think would give you a more pronounced kandy finish in sunlight
Postby GTCRSHR » Thu Feb 09, 2006 10:42 am
theres a course coming up in april which he said might be worth doing,
but i would much rather try and learn my self
ill see how things go and what i finally end up deciding on
im pretty sure i want to go for this candy tho
GTCRSHR
Postby EVL GSXR » Thu Feb 09, 2006 10:50 am
Kandy hhhhmmm I had all the Intercooler Piping and Rocker Cover painted in House of Kolor Wild Cherry Kandy very nice and very expensive.. Lucky mate is a Panel Beater/Painter/Air Brusher and done it for nothing just had to pay for the Kandy which brough enough of to do my whole car (that never got done :( ) .. Layed down a Bright Silver Base and had like 2 - 3 even layer's of the Kandy as All_Fours said must be done evenly as it is easy to notice if a spot has move Kandy then another spot.. Alot harder to get something the size of a Car done then something small like Piping but the end result would be well worth it just wish I got round to doing my whole Car before I sold it :( ..
Good Luck
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby GTCRSHR » Thu Feb 09, 2006 10:52 am
havey ou got any pictures of it ?
why did you go for the silver base ?
GTCRSHR
Pic maybe 56K warning
Postby EVL GSXR » Thu Feb 09, 2006 11:14 am
I have got some pic's but the pic's don't actually pic up the full extent of the colour etc.. Just come's across as a maroon like colour when it's not.. In the sun turn's to a blue, purplely pink colour..
You usually use a bright metallic colour as a base as Kandy is just a clear dye so a dull base wouldn't show any sparkle and come across as dull effect making it a waste of time using Kandy.. I'm no painter but would advise going to see someone that use's it on a regular base's for more info..
Pic below but as I said the Camera doesn't pic up it true colour.. Have some Pic's on my home PC so will have alook tonight..
www.lowndvs.co.nz
EVL GSXR
