Engine Swap Guide
Engine Swap Guide
Postby 2LTR Rona » Mon Feb 13, 2006 8:28 pm
Stumbled across this a while ago from an aussie site if i remember right, could be handy for those possibly looking in to engine swaps, do you see any blatant mistakes or anything to add? Possible for FAQ?
Engine Swap Guide
This list is meant to be a guide about what sort of engine conversions are possible for your Toyota. This is neither definative, nor 100% accurate, but rather based on the opinions and experience of members. If you find any errors, please don't hesitate to get in contact with the webmaster. If you are confused with the engine codes, please refer to our Engine Code Guide. Alternatively, if you are confused with the model codes, please refer to our (you guessed it!) Model Code Guide.
If you don't see your favorite engine (ie: 4A-GE, 1JZ-GTE, 22R-TE), please note that in order to keep this guide readable, it was decided to only include the most powerful engine out of every family (therefore 2JZ-GTE instead of 1JZ-GTE and so on).
Some things to consider when doing an engine swap are insurance, legality (check with the LTSA or an engineer), difficulty, weight transfer, brake upgrades, and cost. Some engines are more suitable for swaps than others also.
International readers, please be aware that this guide is based on Australian models. Model numbers/names and years of availability may differ from those of other countries.
Camry
SV10 (83 - 86) - 4A-GZE, 3S-GTE
SV21 (87 - 92) - 4A-GZE, 3S-GTE, 5VZ-FE, 1MZ-FE
SXV10 (93 - 7/97) - 4A-GZE, 3S-GTE, 5VZ-FE, 1MZ-FE
VCV10 (93 - 7/97) - 4A-GZE, 3S-GTE, 5VZ-FE, 1MZ-FE
MCV10 (93 - 7/97) - 4A-GZE, 3S-GTE, 5VZ-FE, 1MZ-FE
SXV20 (7-97 -) - 4A-GZE, 3S-GTE, 5VZ-FE, 1MZ-FE
VCV20 (7-97 -) - 4A-GZE, 3S-GTE, 5VZ-FE, 1MZ-FE
MCV20 (7-97 -) - 4A-GZE, 3S-GTE, 5VZ-FE, 1MZ-FE
Celica
TA22 (71 - 75) - 4A-GZE, 18R-GEU, 3T-GTE, 3S-GTE, 1UZ-FE
RA22 (71 - 75) - 4A-GZE, 18R-GEU, 3T-GTE, 3S-GTE, 1UZ-FE
TA23 (76 - 78 ) - 4A-GZE, 18R-GEU, 3T-GTE, 1G-GTE, 7M-GTE, 2JZ-GTE, 3S-GTE, 1UZ-FE
RA23 (76 - 78 ) - 4A-GZE, 18R-GEU, 3T-GTE, 1G-GTE, 7M-GTE, 2JZ-GTE, 3S-GTE, 1UZ-FE
RA28 (77 - 79) - 4A-GZE, 18R-GEU, 3T-GTE, 1G-GTE, 7M-GTE, 2JZ-GTE, 3S-GTE, 1UZ-FE
RA40 (79 - 81) - 4A-GZE, 18R-GEU, 3T-GTE, 1G-GTE, 7M-GTE, 2JZ-GTE, 3S-GTE, 1UZ-FE
RA6x (82 - 85) - 4A-GZE, 18R-GEU, 3T-GTE, 1G-GTE, 7M-GTE, 2JZ-GTE, 3S-GTE, 1UZ-FE
ST16x (86 - 89) - 3S-GTE
ST18x (89 - 93) - 3S-GTE
ST20x (94 - 99) - 3S-GTE
ZZT230 (99 - ) - 3S-GTE
Corolla
KE1x - 4A-GZE, 18R-GEU, 3T-GTE, 7K-E, 1G-GTE
KE2x - 4A-GZE, 18R-GEU, 3T-GTE, 7K-E, 1G-GTE
KE3x - 4A-GZE, 18R-GEU, 3T-GTE, 7K-E, 1G-GTE
KE5x - 4A-GZE, 18R-GEU, 3T-GTE, 7K-E, 1G-GTE
KE7x - 4A-GZE, 18R-GEU, 3T-GTE, 7K-E, 1G-GTE
TE7x - 4A-GZE, 18R-GEU, 3T-GTE, 7K-E, 1G-GTE
AE7x - 4A-GZE, 18R-GEU, 3T-GTE, 7K-E, 1G-GTE
AE82 (85 - 88 ) - 4A-GZE, 3S-GTE
AE92 (89 - 93) - 4A-GZE, 3S-GTE
AE102 (94 - 99) - 4A-GZE, 3S-GTE
AE11x (99 - ) - 4A-GZE, 3S-GTE
Corona
ST141 (???) - 4A-GZE, 18R-GEU, 3T-GTE, 1G-GTE, 7M-GTE, 2JZ-GTE, 3S-GTE
RT142 (???) - 4A-GZE, 18R-GEU, 3T-GTE, 1G-GTE, 7M-GTE, 2JZ-GTE, 3S-GTE
TT142 (???) - 4A-GZE, 18R-GEU, 3T-GTE, 1G-GTE, 7M-GTE, 2JZ-GTE, 3S-GTE
Cressida
MX6x - 1G-GTE, 7M-GTE, 2JZ-GTE, 1UZ-FE
MX73 - 1G-GTE, 7M-GTE, 2JZ-GTE, 1UZ-FE
MX83 - 1G-GTE, 7M-GTE, 2JZ-GTE, 1UZ-FE
Crown
MS??? - 1G-GTE, 2JZ-GTE, 1UZ-FE
IS200
GXE10 (99 - ) - 1G-GTE, 3S-GTE, 2JZ-GTE, 1UZ-FE
GS300/GS400
JZS1/UZS1 (91 - ) - 2JZ-GTE, 1UZ-FE
LS400
UZF1 (89 - 94) - 2JZ-GTE
UZF2 (95 - ) - 2JZ-GTE
MR2
AW11 (86 - 91) - 4A-GZE, 3S-GTE
SW2x (92 - 99) - 3S-GTE
ZZW30 (00 - ) - 2ZZ-GE
Starlet
EP91 (96-99)- 4E-FTE
Sprinter
AE86 (83 - 85) - 4A-GZE, 18R-GEU, 3T-GTE, 1G-GTE, 7M-GTE, 1JZ-GTE, 3S-GTE
Supra
MA61 (82 - 85) - 7M-GTE, 2JZ-GTE, 1UZ-FE
MA70 (86 - 93) - 2JZ-GTE, 1UZ-FE
T-18
TE7x (79 - 83) - 4A-GZE, 18R-GEU, 3T-GTE, 1G-GTE, 7M-GTE, 1JZ-GTE, 3S-GTE
2002 Altezza, 1974 KE25
2LTR Rona
Postby 86_rolla » Mon Feb 13, 2006 9:03 pm
FAQ section mayb
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby SnakeEyes » Mon Feb 13, 2006 9:48 pm
Am I to assume that the AE102 Corolla is supposed to be an AE101, and the 102 is a typo?
K<^-^>E
SnakeEyes
Postby wde_bdy » Mon Feb 13, 2006 10:10 pm
SnakeEyes wrote:Am I to assume that the AE102 Corolla is supposed to be an AE101, and the 102 is a typo?
K<^-^>E
Nope, the 102 used the 7A 1800cc I believe.
Callum
wde_bdy
Postby Lloyd » Mon Feb 13, 2006 10:24 pm
What is this guide supposed to tell you exactly? That you can put any FWD toyota engine into a FWD chassis and likewise with RWD? Seems a little... obvious?
Also seems a bit odd to be saying you can put a 1G or a 1UZ in a KE10, when if you're going to that much trouble then why not list 2JZ?
btw, someone find me a 7K :D
Postby Malcolm » Mon Feb 13, 2006 10:27 pm
yeah it's a bit of a basic guide, why would you put a 4agze into a camry? :D
Postby SnakeEyes » Tue Feb 14, 2006 8:46 am
Flawed!
K<^-^>E
SnakeEyes
Postby 2LTR Rona » Tue Feb 14, 2006 8:59 am
All very valid points, but how many times have there been post on here about "what engine can I put in to my ......." only resulting in the first four or five replies being "use the search" followed by one hundred and one questions from the OP, maybe this is a way to remove some of that and give the OP's more ideas?
HRT wrote:What is this guide supposed to tell you exactly? That you can put any FWD toyota engine into a FWD chassis and likewise with RWD? Seems a little... obvious?
To some people yes but to others no, hence some of the questions that get asked and posted
All_Fours wrote:yeah it's a bit of a basic guide, why would you put a 4agze into a camry?
Given the weight of those whales you probably wouldn't, see this as more of a starting point on the thinking path
2LTR Rona
Postby Ako » Tue Feb 14, 2006 11:09 am
You forgot to add 13B / 20B on the majority of them :lol:
Ako
Postby rxtoy » Tue Feb 14, 2006 12:27 pm
this guide was printed in zoom a few years back, along with some sort of warning saying that not all these conversions would be bolt in and easy. i think it was just a compilation of transplants that had been done. however some of these swaps would be seriously expensive and/or involve a great deal of fabrication work.
example: the 1uzfe won't go into the pre 77 celica's without changing from pitman arm to rack and pinion steering. as there is no rack available the right width this requires a great deal of fabrication along with a fair bit of knowledge in setting up steering (bump steer, ackerman angle, etc). putting the engine in gearbox in however isn't that much of a major. you don't have to cut the firewall though which you do for the 1/2jzge conversion which might be why this isn't listed.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby 1loose_mr2 » Wed Apr 19, 2006 5:04 pm
do you know what engines fit into a 90/94 hilux surf
just want to know if a 1jzgte will
1loose_mr2
Postby Silent Knight » Wed Apr 19, 2006 5:49 pm
1loose_mr2 wrote:do you know what engines fit into a 90/94 hilux surf
Yes it will.
And yes, it has been done before although I think it was a 2J from memory.
Silent Knight
Postby Ako » Wed Apr 19, 2006 6:15 pm
Todd from NZPC is in the midst of doing exactly that swap right now.
Ako
Postby Jazza » Wed Apr 19, 2006 6:17 pm
Where are the currens? You can fit any engine into any car with some work :P
Jazza
Postby Silent Knight » Wed Apr 19, 2006 6:18 pm
Jazza wrote:Where are the currens? You can fit any engine into any car with some work :P
This is true.
You can do anything with an angle grinder and some cable ties.
Silent Knight
Postby Bling » Wed Apr 19, 2006 6:40 pm
This is true.
thats pretty rangi!!!!
at least mention the buffer, that thing will take anything back to factory condition :lol: :lol:
Postby 1loose_mr2 » Wed Apr 19, 2006 6:41 pm
who can make engine and gearbox mounts?
can someone give me a list of i need to do the converions
so far ive got
1991 toyota surf,petrol with blown v6 motor,auto
1jzgte and auto box with ecu, loom and fuel pump ect..
and how can i make it just rwd not 4wd what can i do to
the front diff?
thxs
1loose_mr2
Postby Silent Knight » Wed Apr 19, 2006 6:47 pm
I haven't done the conversion myself so I don't know exactly what you would need to complete it...
Doing it RWD is easy. Just don't use the transfer case. I'm not sure whether there is something you would need to change to the front axles though?
You'll need custom mounts for the engine and a gearbox xmember. Your standard hilux xmember might need to be modified aswell depending on where the sump on your 1J sits.
Silent Knight
Postby 1loose_mr2 » Wed Apr 19, 2006 7:08 pm
how much would custom mounts cost :oops: aprox
1loose_mr2
Postby soopachargen » Wed Apr 19, 2006 7:20 pm
just email todd@performancecar.co.nz and ask him what he's done...
When in doubt, down and out.
soopachargen
